Tein RA
Old Jul 1, 2003 | 05:41 PM
John_Z's Avatar
Here are the units. They arrived this evening and I should be able to get the fronts done by tonight. Impressions to follow...
Old Jul 1, 2003 | 07:21 PM
Anthonymv's Avatar
please let us know your impressions
Old Jul 6, 2003 | 07:09 PM
John_Z's Avatar
Okay finished the install on 7/3 and was only able to drive it around town because it was late. First impressions are the ride is a lot smoother and less bouncy than kg/mm race springs & stock shocks. The Tein default fender to floor height is 25 1/2" and the dampers were set 10 clicks back from full stiff. I took a few sweeping 20mph corners at 40mph and the car had virtually no body roll . My final ride height is 25" from fender to floor front and back. The car handles/rides so much better than before and feels very confidence inspiring. I won't be able to fully test the suspension until I get an alignment done, but for all of you who are debating on springs or coilovers...save up for the coilovers. You won't regret it
Old Jul 6, 2003 | 09:07 PM
vapors2k's Avatar
[QUOTE]Originally posted by John_Z
[B]Okay finished the install on 6/3 and was only able to drive it around town because it was late.
Old Jul 6, 2003 | 09:27 PM
John_Z's Avatar
vapors2k,
When you had the teins, did you keep the front/back settings the same or did you make one stiffer than the other? I would think because it's a rear wheel drive car, you would want the rear the same or a click or two softer than the front?
Old Jul 6, 2003 | 09:31 PM
vapors2k's Avatar
[B]vapors2k,
Old Jul 6, 2003 | 09:36 PM
John_Z's Avatar
Thanks vapors2k, so what wheels/suspension/brakes are you upgrading to? Inquiring minds want to know...
Old Jul 6, 2003 | 10:36 PM
vapors2k's Avatar
[B]Thanks vapors2k, so what wheels/suspension/brakes are you upgrading to?
Old Jul 7, 2003 | 03:52 PM
deepdishs2k's Avatar
that some inspiring stuff....if u don't mind telling where did u get them
Old Jul 7, 2003 | 07:36 PM
Money2536's Avatar
I would reccommend corner weighting as well as alignment. Here is what I had done after installing. I have my RA set 12 clicks back in the front and 6 clicks back in rear. This induces a little more snap oversteer.
https://www.s2ki.com/forums/showthread.php?...threadid=133724
freq
Jul 30, 2007 07:11 AM
solomon
Sep 16, 2005 11:23 AM
XtymourX
Aug 25, 2005 10:26 PM
jonam
May 12, 2005 12:23 PM
NECurve
Jul 30, 2004 09:46 PM
