Temp Gauge Problem
Old Jun 27, 2009 | 08:17 PM
Mr Jew's Avatar
Default Temp Gauge Problem
Hey,
Heres a little rundown on whats going on. After driving my car the other day for a while i pulled into a gas station and noticed coolant coming out and the engine steaming a little. Temp gauge never went over 3 bars. I found the bad hose replaced it and got back home with the radiator full. Im not worried about a headgasket issue as the car never shut off and never ran hot. I had a scanner hooked up to it temp never went over 179F. Basically my question is do i maybe have air the system? Is that causing the Temp on the dash to go from 2 to 3 bars and than back to 2 when im crusing? Could be the temp sensor itself. BTW i have NO oil in my radiator so im pretty sure i need to bleed the system. I was reading a little on the process of doing so. It was very clear how exactly do i bleeed? Put the heater on? drain the radiator and than open the bleed screw on the firewall or the one next to the throttle body? Thanks for any info i appreciate it.
Old Jun 28, 2009 | 10:00 AM
Mr Jew's Avatar
any info
Old Jun 28, 2009 | 02:32 PM
negcamber's Avatar
You're probably right that you have air in the system. It can sometimes take several bleedings to get it all out.
Which hose was leaking?
Old Jun 28, 2009 | 03:44 PM
ian02s2k's Avatar
Hmmm, I dont think air in the system would cause your temp to go down. Usually if there is air in the system, it would cause a spike, often resulting in slight overheating and then a sudden cool down. Thats usually what I have run into when I had air in the system.
Old Jun 28, 2009 | 03:50 PM
Mr Jew's Avatar
The IACV hose the longer one of the 2 on top. I posted on S2kca.com and bleeding the system was everyones answer over there. When i drove the car the temp would go to 2 bars. At a light it would go to 3 bars.
Old Jul 1, 2009 | 12:27 PM
PWRMKR's Avatar
replace the thermostat. the seal is trashed and letting coolent through.
Clark
May 11, 2013 02:52 PM
Vinny_GPW-S2K
Apr 11, 2012 09:44 AM
batikan
Dec 29, 2007 09:11 PM
vspc2nr
Oct 2, 2007 05:29 PM
METATRON
Apr 27, 2007 12:28 PM
