Coolant bleeder broken
Old Oct 2, 2007 | 04:17 PM
vspc2nr's Avatar
Default Coolant bleeder broken
Will or can the solider(same used in car electronics) melt?? I used a "T" adapter to split the coolant so i can add a water temp guage doing so broke the OEM bleeder screw. I heated up a good amount of solider and melted it inside the hole so antifreeze wont spew out. Can the heat generated from the motor or even the coolant melt the solder??
Old Oct 2, 2007 | 04:44 PM
Slows2k's Avatar
If the solder's melting point is around 210 degrees it will melt out.
It's probably going to leak anyway due to the different expansion rates.
Old Oct 2, 2007 | 04:51 PM
AusS2000's Avatar
Solder's melting point will be 350F and above so if it melts you have bigger problems. And most solder is eutectic meaning it's melting is point is a point, not a range.
Most old school radiator tanks are soldered to the core.
Old Oct 2, 2007 | 05:25 PM
vspc2nr's Avatar
can i just forget about the bleeder and plug it with the temp sensor gauge ir is it REALLY nessesary??
Old Oct 2, 2007 | 05:29 PM
Slows2k's Avatar
The bleeder sure helps getting the air out of the cooling system. If your car starts overheating from the air pocket I guess it REALLY was necessary.
Carl Bourbon
Mar 10, 2014 11:06 AM
Vinny_GPW-S2K
Apr 11, 2012 09:44 AM
Spec_Ops2087
May 29, 2010 01:22 PM
Mr Jew
Jul 1, 2009 12:27 PM
Rick Hesel
Jul 18, 2002 03:43 PM
