Test Pipe Install
Old Apr 5, 2006 | 06:42 PM
JSWhaler's Avatar
Default Test Pipe Install
So I finally got around to installing my Berk test pipe. After getting it all hooked up the rear 3 bolts match up perfectly, the front two line up and bolt together, but the pipe flange is not flush with the header flange. I started the car up and let it idle and it seems that no exhaust gas/ fumes are coming out of it. Is it ok to leave it like this? My worry is that it is not a flush seam from pipe to pipe. What do you think? Thanks
Old Apr 5, 2006 | 07:20 PM
Harpoon's Avatar
Mine fit like a glove.
Old Apr 5, 2006 | 08:00 PM
xviper's Avatar
As long as that thick donut gasket is in good shape and positioned correctly, that connection doesn't have to be flush. The gasket fills in the space and makes the seal. That's why it's designed like that. If it's flush, then it's a bonus. Run it for a while and then go under and check it again for leaking.
Old Apr 5, 2006 | 08:10 PM
revhi's Avatar
Did you try tightening the front 2 first?
Old Apr 6, 2006 | 05:35 AM
JSWhaler's Avatar
yes, I did. I'll play around with it next week and see what I come up with.
SilliG
Jan 20, 2017 06:43 PM
CoolGuy094
Sep 26, 2013 08:42 AM
Knappster
Mar 6, 2008 05:02 PM
Soul Coughing
Nov 25, 2007 05:17 PM
