Is there a clutch adjustment?
Old Oct 18, 2007 | 08:09 AM
screaminyellow's Avatar
Default Is there a clutch adjustment?
Hey guys, I installed a new clutch and flywheel about 5 months ago and now it seems as though it needs to be adjusted I have to just about release the pedal all the way before it grabs. And if I push it in more then 2 inches it releases.
At first I thought I might have trashed this clutch already but when I rev it then dump it, it still grabs hard!
So is there any way to adjust this?
Old Oct 18, 2007 | 01:36 PM
slalom44's Avatar
Top Answer: 1
The good news is that it doesn't look like you have any air in your clutch line!
Yes, you can adjust the linkage. Personally, I've never done it but several members have. You need to loosen the locknut and back off the clutch switch (above the pedal), then loosen the locknut on the pushrod and adjust it to where you want it. Tighten the locknut. After that, put the clutch switch back and tighten the locknut on that as well.
Old Oct 18, 2007 | 02:05 PM
Thank you for the reply, I will try that tonight when I get home!
Old Oct 18, 2007 | 07:33 PM
nightcrawler7188's Avatar
yeah if you have the shop manual it's in there too (not the owner's manual).
Old Oct 19, 2007 | 07:38 AM
I have access to All-Data. Maybe it is in there.
drewc
Aug 8, 2015 01:07 PM
cmn
Jan 30, 2011 12:41 PM
thischarmingman
May 9, 2009 03:43 PM
Gh0ztt
Feb 18, 2008 06:43 PM
s2kbtos
Aug 11, 2007 07:46 PM
