Thinking of changing suspension set up
Old Jun 19, 2006 | 11:47 AM
IIGQ4U's Avatar
Hi,
I haven't really heard much in regard to dislike for the Koni shocks??? They may have become damaged or were defective upon purchase?
As far as the KW's... Yes ride height is individually adjustable as well as the rebound and high speed compression.
The Spring rates of the KW's are 515 lbs front and rear and they can be adjusted for a fairly mild street ride or kidney rupturing track setup.
Old Jun 19, 2006 | 12:02 PM
pikkashoe's Avatar
I think the weak link in my set up is not the Koni's but rather the ground control's.
So the ride height is totally independent from spring rate, on my GC's, to set ride height, you basically compress the spring updward or downward, thus changing the spring rate.
Hmmm, time to spend more money!
Old Jun 19, 2006 | 12:26 PM
IIGQ4U's Avatar
Hmmm
I do not believe that the ride height is independent from preload. By altering the ride height, you are increasing or decreasing the preload. I would imagine that this would be the case on any coilover system.
Old Jun 19, 2006 | 01:04 PM
mikey k's Avatar
Hence the need for the manufacturer to "tune" the spring and damper. I've just has problem with mine where Nitron assumed +04's are the same as 99-03. They now want the car to take measurements and allow them to select the correct spring and matched damper.
Old Jun 19, 2006 | 03:49 PM
pikkashoe's Avatar
From what I understand, the buddy clubs allow independent ride height adjustment, which does not affect preload/spring compression rate. Nice nitron's. I cant afford to go that high end.
Old Jun 20, 2006 | 11:10 AM
mikey k's Avatar
Looking at the ones in this thread you might be right but only to a small extent. A small height adjust could be made on the lower adjuster. Top adjuster is similar to my Nitrons which give the most height adjustment.
Buddy Clubs
99-03 Nitrons on 04 car with height adjustment issues
Rear @ 30mm drop
Front @ 30mm drop but fully preloaded
I'm at Nitron on Friday to "measure up" for the right ones!
Old Jun 20, 2006 | 11:16 AM
IIGQ4U's Avatar
The ride height adjustment is independent from perhaps compression and rebound.
If you are really raising or lowering your car, preload will be affected.
Old Jun 20, 2006 | 01:30 PM
mikey k's Avatar
that was my understanding of all coilovers
calvinnnnn
May 28, 2017 06:42 PM
decepticondc5
Dec 25, 2016 01:49 AM
chillout18
Apr 14, 2008 07:56 AM
xS2K PRODIGYx
Jan 15, 2006 12:51 PM
doorman
Aug 10, 2005 01:19 PM
