Thinking my tranny is done.
Old Dec 28, 2006 | 06:25 AM
JDMilanoEG's Avatar
Default Thinking my tranny is done.
Ok so my master cylinder is on its way out, I have yet to replace it. I have had some difficulty getting the car into 4th and 5th when accelerating fast. Like if I merge onto a highway and im in 2nd I can floor it and hit 3rd perfect but 4th and 5th crunch going in and are VERY difficult to get out. I know this is probably the synchros. But would they make it VERY hard to take out of the gear? If im driving normal light to light the car goes in gears fine and after about a day or so it comes out easy and goes back to feeling just fine. I am currently running mobil 1 75w90 in the tranny. I just wanted to know if anyone has any suggestions short of getting a new trans. Thanks!!!!
Old Dec 28, 2006 | 06:38 AM
clawhammer's Avatar
75W90 goes in the differential, not the transmission.
Change it out to the new Honda MTF ASAP!!! See if the problem goes away just by changing the fluid.
Old Dec 28, 2006 | 06:45 AM
SpitfireS's Avatar
Mobil 1 75W-90 is a gear oil, but it may contain sulphur and that is BAD for brass synchro's.
Sulphur eats brass for breakfast
Change it - like clawhammer mentioned - to Honda's MTF or a simular manual transmission oil as soon as possible, maybe flush once (or twice) to make sure all the old oil is out.
Manual transmission oil is a LOT cheaper then new synchro's.
There have been posts from at least one other person using that Mobil 1 75W-90 without any ill effects (for a year IIRC) in the transmission, but I would not risk it.
Also.. do you skip shift?
If so, stop doing that.
5th gear synchro was designed to deal with rev differences from 4th and 6th, NOT 3rd or 2nd.
Old Dec 28, 2006 | 07:04 AM
JDMilanoEG's Avatar
Yeah I used to skip shift back when I first got the car and the car reacted similar to how its acting now and I stopped and have never done it again. The problem went away after that. I was also thinking that with the cold weather here the fluid in the tranny is far too thick. Guess I now have plans on changing the fluid this weekend.....in the cold...lol. Thanks guys.
Old Dec 28, 2006 | 07:13 AM
ivia12copolo's Avatar
wats up guys, I was jus wonderin how difficult it is to use the MTF, I bought to qts of Red Line mt90, I hear its the good stuff.
Old Dec 28, 2006 | 03:55 PM
JDMilanoEG's Avatar
Its not to hard. Just gotta put the car up on jackstands, drain it than fill it. im sure theres a writeup on here with pics...run a search.
Old Dec 28, 2006 | 05:12 PM
KnowledgeIsPower's Avatar
there is a writeup of a DIY in the top of this forum by Xviper.
gl with the tranny
Old Dec 28, 2006 | 05:41 PM
milkbubble's Avatar
https://www.s2ki.com/forums/index.php?showtopic=83577
Old Dec 29, 2006 | 01:53 PM
Thanx guys!!
Old Dec 29, 2006 | 02:38 PM
common reactor's Avatar
It could have something to do with the weather...this car drives so much different in the cold it's not even funny.
brendanj85
Dec 13, 2008 04:30 PM
1.8TsBLOW
Feb 16, 2008 02:05 PM
basracx
Jul 15, 2007 10:00 PM
golfnut311
Dec 1, 2002 03:07 PM
OneQuickS2K
Jun 7, 2002 01:51 PM
