Threw a CEL, getting unknown DTC-blink code
Old May 12, 2007 | 03:07 PM
futique's Avatar
Default Threw a CEL, getting unknown DTC-blink code
My 05 developed an idle hunting issue this morning- it will go from 1000RPM to 2500RPM while idle, in a rhythmic fashion....
I parked it, and pulled the DTC manually using blink codes, and got the following:
1 long, 4 short = P0113 --------------- IDLE AIR CONTROL (IAC) VALVE
(Makes sense given symptoms....)
Here's the strange part, the second code that pops up is:
10 long, 9 short = ??????????????
Anyone have any idea what this could be? I'll find out on Monday when I take it in for service, just curious what it might be....
Old May 12, 2007 | 05:25 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
IAC valve is stuck.
Remove it, spray inside with wd-40, reinstall, tap it lightly with a screwdriver handle while the engine is running.
Seen/fixed this many times....
Old May 12, 2007 | 08:19 PM
futique's Avatar
Thanks...
It's under warranty- shouldn't I just have it replaced?
Any thoughts on the second mystery code?
Old May 13, 2007 | 09:05 AM
R3DS2K's Avatar
under warranty. you can take it in and have them find out ... or do what billman recommended
s2kprax
Jul 31, 2018 06:38 PM
j03chu
Jun 3, 2012 03:33 PM
Mister Jew
Mar 13, 2007 09:45 PM
vermillion
Mar 13, 2007 03:36 AM
