Throttle cable
Old Sep 22, 2009 | 12:47 PM
Tech7427's Avatar
Default Throttle cable
As the title states, anyone know of another chassis throttle cable that will work and be shorter than the rather overkill length of the stock throttle cable?
thanks.
brian
Old Sep 22, 2009 | 01:06 PM
jeffbrig's Avatar
What problem are you trying to fix?
The amount of slack in the throttle cable is adjustable. And, as long as putting your foot on the floor fully opens the throttle body, I can't think or any valid reason to change it. I know some people like to adjust out all the slack for "more response", but then you risk snapping the cable when you stomp the pedal.
Old Sep 22, 2009 | 01:38 PM
Tech7427's Avatar
not trying to fix any problem.
i dont want the awfully long cable for no reason.
Old Sep 22, 2009 | 04:23 PM
jyeung528's Avatar
i'm so confused...
why is it awfully long?
Old Sep 22, 2009 | 04:37 PM
Stratocaster's Avatar
Originally Posted by jyeung528,Sep 22 2009, 07:23 PM
i'm so confused...
The 00-05 Cables loop around under the hood. There is about an extra 1.5 feet of cable.
Old Sep 22, 2009 | 04:45 PM
Slows2k's Avatar
I think this is one of those things that is easier to leave alone what works.
Old Sep 22, 2009 | 04:56 PM
That is what I did.
Old Sep 22, 2009 | 04:57 PM
jyeung528's Avatar
is there any benefit to using a shorter cable? i hope you don't say weight savings...
Old Sep 22, 2009 | 05:02 PM
Slows2k's Avatar
It won't have a loop in it.
Old Sep 22, 2009 | 05:28 PM
jeggy's Avatar
switch over to DBW if it bother you that much. but that is probably a can of worms you don't wanna open.
