"thunk" when backing?
what's the torque rating of the gun ?, my ingersoll-rand gun snapped mine off like nothing at 90 psi and my compressor is relatively simple. My axle nuts weren't touched in 9 years and wouldn't budge with a normal breaker bar, but the gun worked great. I barely unstaked the nuts too, the gun did all of the work.
http://community.craftsman.com/Craft...Wrench-reviews
I just tried what one of the people said to try. I can set it to highest torque and actually grip the socket and it won't spin. Wtf. Maybe it's broken. Problem why I can't get it to break anything loose
Sounds like you have the 3/8" dia hose which should be sufficient.
When was the last time you oiled the gun? If it's been a long time ago, it's probably best take it apart, clean the vanes, and then oil them individually.
I've used that gun before and it has enough power to undo 180 ft-lbs.
I just got this particular gun last week, I oiled it the first time I used it, but haven't since, just used to pop a few bolts off, then oiled it and sat it in a drawer in my garage
Drive size: 1/2"
Impacts per minute: 650 ipm
Free Speed: 7,400
Ultimate Torque: 400 ft. Lbs.
Weight: 4.2lbs
average air consumption: 5.2 scfm
air hose size: 3/8" I.d.
air inlet: 1/4" npt
Max air pressure: 90 psi
Is the gun OK?
Free Speed: 7,400
Weight: 4.2lbs
air inlet: 1/4" npt
Is the gun OK?
Run it at 90 psi and see if it works any better, not sure if upping the psi setting helps or hurts on smaller compressors. Otherwise it sounds like the gun is bad if you said that it would not exert pressure when held in your hand ?
What's the psi on the compressor outlet? If it's 90 psi, then the pressure is not high enough.
