time to rebuild?
ok i have a knocking sound coming from my bottom end, it sounds like a rod knocking, it only happens around 3000 rpm`s and only when the car is warm.. its not really loud but you can definately hear it when accelerating
so now i am thinking hat i need to do a rebuild.
you guys are more experienced with this topic so my question is what would you recommend,
fixing the rod knock or change the bottom end to a 22 and what are the pros/con of both ideas
thanks guys
thanks guys
I think you need to take it to someone who can diagnose sounds. So many things in our engines can make a clunk or clank. TCT is a pretty specific sound, and it repeats much faster than the engine is rotating.
Originally Posted by AusS2000,Apr 13 2008, 05:41 PM
A guy here had a knock. Turned out he had dropped something down behind the engine and it was banging on the transmission tunnel.
I just hope you can be as lucky.
ok guys i droped the oil pan today and siting in my oilpan was my thrust washers, everything else seems good , all the rods seems fine, but the rear thrust washer is worn really bad, i think this is a result of the clutch that is installed on the car
