Timing Chain Tensioner Mod
Old May 24, 2023 | 06:11 AM
Chuck S's Avatar
The "TCT hack" is well known to work -- for a while. OCONUS guys have few options. US guys, including those in Alabama , have a known superior, reliable TCT available.
-- Chuck
Old May 24, 2023 | 06:16 AM
B serious's Avatar
Originally Posted by WallaceS2K
When I bought my S2K the OEM TCT was loose, being in the UK Billman's TCT's are not so obtainable so I roughed up the worm gear and drilled out the oil ports myself. It's now been running fine for about 3k miles and 4 track days.
Just because someone hasn't thrown an aftermarket part at the problem doesn't mean they're being cheap, engineers like to find solutions to problems not just throw money at them.
Bruv, no offense, but you've drilled a hole, sanded a worm gear, and have now tried it for a mere 3K miles without any perceived issue.
I wouldn't call any of that engineering.
Doing something like this is also not for everyone. There's a lot that can go wrong.
OP really should post why he wants to do this so proper advice can be given. But I'm not sure we'll ever cross that bridge.
Old May 24, 2023 | 07:18 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Let’s lay out some facts:
-the simple act of removing and installing the tct (without doing anything to it) can alleviate the noise for months. It does not fix the underlying issue
-any type of hand sanding, with any type abrasive, will reduce the worm gear contact inside the piston, causing bleedout through the piston. It will lower the pressure inside the tensioner. The point of glass beading the worm gear is not to rough it up. It allows the worm gear to wear into the piston, INCREASING its surface area, the same as honing the cylinders allows the rings to wear in to the cylinder walls. If you are not going to glass bead or mildly sandblast the worm, leave it alone. Glass beading the worm has limited success, but has helped some.
-but most importantly, which is something the video did not show or state, was if the noise was tensioner related. There are many noises this engine can make, and doing tct mods will not cure any of them.
-are you sure the noise you are hearing is tensioner related? Post a sound clip if you like. TCT noise is easy to distinguish.
Old May 24, 2023 | 09:52 AM
Slowcrash_101's Avatar
The underlying issue is the chain stretching and taking the TCT out of its calibration range. Billman's TCT is really the best solution, because it's a permanent fix, it increases the calibration window of the TCT, and it bolts up like stock. I prefer it over the Toda TCT, considering the quality of the part is above the Toda version and is cheaper even without the core refund, I don't see the issue.
Old May 25, 2023 | 04:04 AM
WallaceS2K's Avatar
Engineering to me is problem solving by design and development, it may be that what I've done is only a temporary fix and as Billman stated it may only be the removal and re-install of the TCT that is the reason for the noise having gone but it's still problem solving.
I'm not saying what I've done is the final or most effective fix but it is working so far and even Billman's TCT has gone through numerous revisions to get to the design he currently uses - which I'd also call engineering.
As you stated doing it yourself is not something everyone will want to do but equally some people would rather try to find a solution themselves instead of just purchasing a part that someone else has done the engineering/R&D on. There's obviously a few aftermarket options for this but all I'm saying is someone shouldn't be shot down or belittled (that's not aimed at your comment btw) just because they don't immediately want to spend money when there may be other options to try.
Old May 25, 2023 | 10:50 AM
Car Analogy's Avatar
Agree that R&D, experimentation, is indeed engineering.
What everyone is saying though is this isn't a safe place to experiment.
Its not just about getting it wrong, but simply not getting it right can easily destroy your engine. See Billman post.
We couldn't in good conscience not strongly recommend the proven solution that can just be purchased off the shelf.
Old May 25, 2023 | 08:13 PM
Mr.Matchbox's Avatar
When you live Outside the USA, simply buy a Toda or the new Blox TCT and you are done.
Old May 26, 2023 | 07:08 AM
WidWidi's Avatar
Default Timing Chain Tensioner Mod
Originally Posted by Chuck S
Time to pile on!
Hopefully your "non-OEM" TCT isn't a "Brand B" some of which have caused engine damage.
I admit to not watching all 20 minutes of the video because sanding or sand blasting the internals of the OEM TCT is a very common long used temporary fix for the TCT. Temporary. Symptoms can come back quickly and new OEM TCT failure has been reported here. Billman's TCT is a one-and-done change. I can't recall any failures unlike sand blasted, new OEM, and "Brand B" TCTs (which have reportedly caused engine damage). Takes 10 minutes to install and so easy I did mine right after work the day it arrived and didn't bother changing into work clothes only removing my tie. I installed mine as preventive maintenance. 10mm wrench and a paper towel are the exotic tools required.
-- Chuck
Chuck, can you please explain for me what a b series TCT is?
Old May 26, 2023 | 07:25 AM
Save the Manual Wagons!'s Avatar
Chuck is probably referring to Ballade when he talks about a "Brand B" tensioner. It's a garbage product that can (and probably will) dump metal shavings into your engine. I don't see any reason not to call it out by name.
There are a bunch of threads about the Ballade TCT.
Old May 27, 2023 | 02:24 PM
B as in Ali Babba brand? The Japanese corporation that built the TCT is NTN, they have subsidiaries Nissin and Adler, so if you get a TCT from one of those brands you know you're getting the factory spec TCT. Any other TCT is a cheap knock off, and should be skipped. All the good TCTs Stock/Billman/Toda use the factory TCT as the foundation.
