Timing Cover Removal
Old Aug 28, 2012 | 09:47 PM
RedSunS2K's Avatar
Default Timing Cover Removal
I'm having a very hard time removing the cover. I'm pretty sure I removed everything in its way and holding it down. Where exactly are the pry locations? The oil pan was very easy but this thing just wont budge!
Here's a picture. Let me know if I forgot to remove something.
Old Aug 29, 2012 | 02:09 PM
herecomesboost's Avatar
Your crank position sensor, while unbolted, is still sitting in place. While that's not the reason you can't break the timing chain cover loose, I would recommend removing it completely before prying on the timing cover. There should be tabs (I don't recall their exact location) in place for you to pry. I used a small flat head screw driver.
Old Aug 29, 2012 | 03:40 PM
DeeKay's Avatar
Any in the bolts from oil pan? Grey sealer can fight you but not with a decent pry bar. Can you pry on the right side behind the orange plastic?
Old Aug 29, 2012 | 05:03 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There is one bolt slighty hidden....right behind the crank sensor wire. Its a short one.
The timing cover will take quite a bit of force to break the original grey sealer.
Let me know if you break it I have 10 of them.
Old Aug 29, 2012 | 07:30 PM
RedSunS2K's Avatar
Got it off. Someone clue'd me in and told me a prying location. Bottom left corner. Little elbow grease and popped right off. Thanks guys!
S2k_razy
Mar 1, 2015 02:42 PM
Fatbloke
Feb 28, 2015 08:33 AM
sanjuro
Feb 13, 2014 01:39 PM
nicholasbartleet
Nov 5, 2009 03:38 AM
05TurboS2k
Jan 14, 2008 08:12 AM
