How can i do this?
im working on my car atm. i've taken all bolts and pulley out of the way. now im ready for the chain cover to come off. how do i take it off? because it seems to be glued to the engine. any suggestions??
it is glued on with Honda bond sealant. I haven't touched mine but you will need to pry it loose, a long flat head screwdriver should do it, pry between the block and the cover. Honda often puts pry points around their sealed covers, I would start with the top though as the easiest access point.
