timing gear teeth
Old Jul 8, 2009 | 03:07 PM
street_ruler's Avatar
Default timing gear teeth
anyone ever notice how the timing gears on our cars seem to ahve 2 sets of teeth cut into them? one set is about 3/4ths of the way deep and the other set is the remaining quarter? anyone know why that is?
reference this thread for pics
https://www.s2ki.com/forums/index.php?showtopic=711108
Old Jul 9, 2009 | 07:33 AM
buhler?
Old Jul 9, 2009 | 09:57 AM
Stratocaster's Avatar
They are built like this to be quiter. They sissor together on the timing gear instead on chattering.
Old Jul 10, 2009 | 10:15 AM
SpitfireS's Avatar
Don't search for "scissoring" with Google images.
Old Jul 10, 2009 | 05:02 PM
Habitforming's Avatar
it's not herringbone, that looks like this: <<<<<<<< from the side, or this image
they are scissor gears, which are used on all timing chain engines these days. There is a spring inside which forces them away from each other to a certain degree. The idea, as Strat correctly pointed out, is to reduce noise in the chain system by minimizing slop.
Old Jul 11, 2009 | 06:46 AM
SpitfireS's Avatar
I guess the correct technical name for them is: anti backlash gears.
And this is what the insides look like:
This is a pretty simple & effective design.
It uses a circular spring, it looks a lot like a big circlip.
The gear with the spring is the main gear, the one on the right is the anti backlash gear.
In the bottom left picture you see how much the two gears are able to move and make the teeth look misaligned.
The bottom right picture shows how they look like when the gears teeth align.
(without the spring installed)
P.S. I have not managed to put them back together again as the spring is pretty strong.
Therefore I can not drive my car.....
J/K.
These are from my old MY00 engine
Moddiction
Nov 19, 2014 11:51 AM
MB
Mar 5, 2011 01:30 PM
neeman77
Nov 9, 2010 09:56 PM
vollrathian
Mar 15, 2009 04:04 PM
Mr. Francesco
Jul 18, 2004 07:42 AM
