Tire usage
Old Jun 20, 2009 | 08:55 PM
freddy14's Avatar
Default Tire usage
My S eats up my rear tires from inside to out is that normal i though they would waste evenly
Old Jun 20, 2009 | 09:11 PM
chansta's Avatar
inside to out meaning the center of the tire right?
check ur tire pressure... might be too high.
Old Jun 21, 2009 | 08:42 AM
takeshi's Avatar
It's completely normal. The S isn't your parents' sedan.
Start here:
http://en.wikipedia.org/wiki/Camber_angle
and then search around for camber.
Old Jun 21, 2009 | 08:58 AM
WarrenW's Avatar
Did you or a previous owner (assuming yours is used) have a negative camber set up? That'll eat through tires faster than a zero camber set up, but it won't handle as well if you like pushing the car into the corners.
Also, what tires are you using? I have Goodyear Eagle F1's, GS-D3 and they wear out quick, 15-20k mi. I'm thinking of finding some other tires for it because of the wear issue but the problem is I don't want to lose the grip but with what these tires cost, even from Tire Rack, I think I'm going to have to bite the bullet and go with something else.
Old Jun 21, 2009 | 03:09 PM
M2K's Avatar
M2K
stagger tires will wear out from the in to out .
Old Jun 22, 2009 | 11:22 AM
mxt_77's Avatar
Get an alignment. Excessive toe will cause increased wear.
Also, as stated, if it is wearing in the middle of the tire, you're likely over-inflating the tires. Something around 32psi cold pressure is usually a good place to start.
Old Jun 22, 2009 | 12:05 PM
TheProfessor's Avatar
HAte to tell ya mxt_77 but toe dont wear tires.
Old Jun 22, 2009 | 12:25 PM
TookayS2K's Avatar
you are wrong.
Old Jun 22, 2009 | 12:40 PM
CKit's Avatar
Normal if you have a lot of straight-line driving.
Old Jun 22, 2009 | 01:01 PM
mxt_77's Avatar
lol wut?
Toe will wear tires much faster than camber will.
Think of it... if you have non-zero toe, then you're effectively "dragging" the tire sideways as you drive (since it's pointing in a different direction than the direction of travel). However, if you have zero toe, but non-zero camber, then the tire is still spinning/turning in the correct direction; however, you're just putting more weight on a smaller portion of the tire.
