toda cam gears
Old Mar 22, 2004 | 02:07 PM
bunjimobile's Avatar
Default toda cam gears
I putting money aside to purchase Toda Cam gears. My only worry is because it's only a 4-bolt design will it slip? Has anyone with Toda cam gears have slippage problems?
Old Mar 22, 2004 | 02:37 PM
Urge's Avatar
Sponsor
Todas cam pulleys have six bolts..
http://www.todaracing.com/products/honda_s...campulleys.html
They seem to be the only option for adjustable cam timing on the market (maybe due to chain-driven). Anything else is probably custom.
__________________
Old Mar 22, 2004 | 02:45 PM
BenR's Avatar
What are they talking about when they say the std cams are made from solid blanks and theirs are hollow.
Std cams are hollow!
Old Mar 22, 2004 | 02:52 PM
All the pics that I've seen before showed only 4 bolts............I guess I was looking at the wrongs pics before. Thanks for the pic confirmation. So back to the first question.......with 6 bolts I know chances of slippage are greatly reduced but has anyone had those problems?
Old Mar 22, 2004 | 02:59 PM
BenR's Avatar
No cam pully setup i have run has ever slipped unless not done up, even the 4 and 5 bolt pullies.
I wouldnt worry.
Old Mar 22, 2004 | 03:12 PM
Raymund's Avatar
One more thing to consider is these gears will be submerged in oil increasing the likely hood of slipping if the bolts are not torqued properly. soft grade locktite should help.
Old Feb 6, 2009 | 09:10 AM
maluch's Avatar
does anyone know if the toda cam gears have the spring inside them? it looks to me like they do not have anything like that? what do people think of its inability to reduce whiplash? this is the first cam gear that i have seen that has this functionality so maybe it's not that important? Maybe its just a noise thing?
Can someone describe how exactly it works in relation to the two halves?
Old Feb 6, 2009 | 09:36 AM
Stratocaster's Avatar
Submerged? What are you talking about. Try coated, but they will never be submerged.
Now my question to the OP, why do you think you need adjustable cam gears any way? Are you running an adjustable ECU? (AEM EMS, K-Pro)
Old Feb 8, 2009 | 06:07 AM
briggle's Avatar
They will not slip unless you under torque them by some stupid amount. The only TODA set I saw had some redundancy built into it, if you pulled the two pieces apart there was some grooves that would only allow for the movement in 1/2 to 1 degree increments. Thus these degreed grooves held the forces and not the bolts. I have not seen a set for an S2000 yet though.
s2kvice
Apr 7, 2012 06:35 AM
ninekallday
Dec 21, 2009 09:04 AM
qbmurderer13
Feb 7, 2009 02:30 PM
Roll_On_S2K
Apr 24, 2007 04:18 PM
S2000_Europe
Feb 15, 2006 06:01 AM
