Toda Cam problem
Old May 30, 2005 | 09:58 AM
demonderrick's Avatar
Default Toda Cam problem
I purchsed the Toda cam (the very first release verion the version I) with exhaust side valve spring, during the via-ocean-shippment, the cam got rusted and the cam has some burn-out on it. But, it seems OK since the cam is not bent or others.
However, after the install, we found that once the rev goes to 8000'ish rpm, then the power loses huge, however, what might be the problem?? May it be the valve springs not strong enough for the intake/exhaust side (install the valve springs to the wrong side?) ?
Old May 30, 2005 | 10:42 AM
Correct me if I am wrong, I believe the intake side valve springs should be doted blue?? is this correct?
Old May 31, 2005 | 10:45 AM
VeilsideAP1's Avatar
Dude, I lost a motor to these cams, and made neglidgable power tuned... my advice would be to dump them... the revised version that is silver seems to be doing alright for some other owners, but if you got the first run (cams were black) get out while you can...
Old May 31, 2005 | 08:27 PM
mingster's Avatar
hey derrick, you're still around? PM me sometimes!
skittzomaniac
Jan 28, 2005 05:41 AM
mikecl713
Oct 23, 2004 11:14 AM
silver2000
Jan 21, 2004 03:02 PM
Stealth Operator
Jun 17, 2003 04:40 PM
demonderrick
Apr 10, 2003 05:05 AM
