torn wire
Old Apr 18, 2017 | 12:04 PM
jXxviii's Avatar
Default torn wire
it runs to behind the hub near the center. what is this wire for and what happens now?
Old Apr 18, 2017 | 12:09 PM
jwzimm's Avatar
Probably for the tone ring for the ABS and/or the VSA (if equipped). It is important and you should fix it or your ABS will be non-functional.
Old Apr 18, 2017 | 05:17 PM
Slowcrash_101's Avatar
Yep wheel speed sensor cable.
Old Apr 18, 2017 | 11:36 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Likely broken during suspension install.
A new ABS sensor will come with a new wire.
Also note it appears your brake hose may have a 360 degree twist in it from caliper removal.
Old Apr 19, 2017 | 03:02 AM
Upper control arm bushing is torn as well.
Old Apr 19, 2017 | 07:10 AM
sdosmil77's Avatar
+ hands are dirty.
Old Apr 19, 2017 | 11:59 PM
jXxviii's Avatar
Sigh vsa/abs lights are on as I was afraid of.
uca bushings are intact, just the normal 80k of wear, I think you must have mistaken because the arm was disconnected in the picture
Old Apr 20, 2017 | 12:15 AM
jXxviii's Avatar
I don't have experience with wires, but if i twist the two together, and climp it with this, would that secure a long lasting connection? Does this require soldering? I appreciate the help guys
Old Apr 20, 2017 | 04:30 AM
flanders's Avatar
If you use a good quality heat shrink (the one with glue) over the crimp it might last.
But I would rather solder it and use glue lined heat shrink.
Old Apr 20, 2017 | 08:43 AM
hoobastnk90's Avatar
I would use solder and shrink tubing. You don't want water getting into there and causing issues while your driving.
