Torque Assy unit
Old Feb 4, 2025 | 08:25 PM
scotty2k2's Avatar
Default Torque Assy unit
is there an aftermarket part that is compatible with 53101-S2A-A02?
Old Feb 4, 2025 | 09:09 PM
B serious's Avatar
No, it does not seem so.
Why do you ask?
Old Feb 5, 2025 | 03:07 AM
scotty2k2's Avatar
Why do you ask?
because mine went bad according to the service department at Honda
Old Feb 5, 2025 | 01:34 PM
B serious's Avatar
Gotcha. But why the aftermarket question? Are you unable to buy the Honda one? Or a used one?
Old Feb 5, 2025 | 04:08 PM
JBamin's Avatar
those have been a tough find for a while.
Old Feb 5, 2025 | 05:26 PM
scotty2k2's Avatar
The part has been discontinued. Some are saying the part ending in A03 works.
Old Feb 6, 2025 | 04:46 AM
Slowcrash_101's Avatar
You can take it apart and clean it, make sure the slip ring on the torsion bar isn't binding.
You can use any torque sensor, so you can use the AP2 or CR torque sensor on your AP1 with no issue.
If you feel brave the Mazda 6 from 2007-2011 has the same torque sensor as our cars. PN GS1F3212Y
These are the 2 torque sensors(Mazda aftermarket on top, Honda OEM on bottom), the only visible difference seems to be the metal housing the plastic sensor housing bolts to. That's not a big deal though because you can just transfer the aluminum housing from your old sensor on the new one and it should bolt right up to the rack.
Old Feb 6, 2025 | 06:07 PM
JBamin's Avatar
the shaft gear seems to be spun the wrong direction?
Old Feb 7, 2025 | 10:40 AM
Indeed.
Shame too, as the shaft is the one that wears beyond repair and not the plastic housing.
Old Feb 8, 2025 | 03:53 AM
Scigheras's Avatar
Looks like it might work fine for RHD S2000 then
Picture 1 of 2
Maybe you guys over there need to find a LHD Mazda torque sensor?
