torque specs
ok so I removed my tranny to change my clutch now that I'm putting everything back together I'm tryin to find out what each bolt is supposed to be torqued to. I dont have a helm manual but I figured someone on here may have done a write up.(I did a search but didnt see anything)
All the larger Tranny bolts are 47ftlbs ( 17mm socket )
The two bottom smaller ones are 33ftlbs ( 14mm Socket)
The three that hold the cross member under the shifter are 28ftlbs (14mm socket)
The front subframe .. the four larger ones are 86ftlbs ( 19mm socket ) the two smaller ones are 43ftlbs ( 17mm socket )
All the 6mm ( 10mm socket) around the shifter boots top and bottom are 7 ftlbs
The 8mm drivshafts bolts 24ftlbs ( 6mm allen )
My shop rate is $79hr for service
LOL J/K
Good luck , hope it goes smoothly for you , I am out of here
LOL J/KGood luck , hope it goes smoothly for you , I am out of here
GhostWKD
Car Talk - Non S2000
Feb 27, 2014 06:21 AM
