torque specs
Old Dec 8, 2007 | 02:21 PM
cbrguy7's Avatar
Default torque specs
ok so I removed my tranny to change my clutch now that I'm putting everything back together I'm tryin to find out what each bolt is supposed to be torqued to. I dont have a helm manual but I figured someone on here may have done a write up.(I did a search but didnt see anything)
Old Dec 8, 2007 | 02:26 PM
ScottyBallistic's Avatar
94 ftlbs for the flywheel to crank
19 ftlbs for the pressure plate to flywheel
Old Dec 8, 2007 | 03:15 PM
cbrguy7's Avatar
what about the differential , subframe,and the tranny bolts?
Old Dec 8, 2007 | 03:29 PM
All the larger Tranny bolts are 47ftlbs ( 17mm socket )
The two bottom smaller ones are 33ftlbs ( 14mm Socket)
The three that hold the cross member under the shifter are 28ftlbs (14mm socket)
The front subframe .. the four larger ones are 86ftlbs ( 19mm socket ) the two smaller ones are 43ftlbs ( 17mm socket )
All the 6mm ( 10mm socket) around the shifter boots top and bottom are 7 ftlbs
The 8mm drivshafts bolts 24ftlbs ( 6mm allen )
My shop rate is $79hr for service LOL J/K
Good luck , hope it goes smoothly for you , I am out of here
Old Dec 9, 2007 | 01:04 PM
cbrguy7's Avatar
Thanks man I'm pretty excited about gettin her back on the street it's been almost 2 months now.
Old Dec 9, 2007 | 01:16 PM
NP , glad it worked out for you ......
GhostWKD
Car Talk - Non S2000
Feb 27, 2014 06:21 AM
99SH
Nov 21, 2011 03:50 PM
ChefJ
Jul 11, 2010 02:16 PM
willyang
Apr 9, 2005 03:44 PM
cdelena
Oct 10, 2002 06:18 AM
