tps voltage on 2000 s2000
Slowcrash, is the 6% & 90% readings spec found in the service manual ?, or just what you have observed on a stock throttle body ?. I've played with my J's Racing throttle body in the past to try and set it properly and I think I had it around 4% idle and 88% WOT. If it should be 6% idle I'd gladly change my tps setting as my I wouldn't mind a bit more idle rpms. Thanks for any additional info on this.
