Tranny Question
Old May 2, 2012 | 02:00 PM
erinehart5001's Avatar
Default Tranny Question
hey fellas, this may be a dumb question but it needs answered. Im living in Germany right now and of course we have the autobahn. Recently when I do a 200+ km/hr pull for a few miles I notice my gears begin to "stick" or become hard to shift. The downshift from 6th to 5th is fine but starts hanging up when going from 5th to 4th and so on. I understand that its the tranny getting hot and all but is this normal. After it cools there are no problems. Would changing the fluid help? Im running Amsoil right now and just wonder if it has broken down since the last time I changed it. Any input will help.
thanks
Old May 2, 2012 | 02:03 PM
rob-2's Avatar
Changing the fluid should help
How long has the fluid been in there?
Old May 3, 2012 | 03:30 AM
TougeS2k's Avatar
def change the oil!! My gears stick here and there but i dont think its heat related (for me)
Old May 3, 2012 | 04:47 AM
Paul Boz's Avatar
Change the fluid and maybe look into fabricating a heat shield for your exhaust near the transmission or wrapping the exhaust near the transmission if the problem persists after an oil change. You might also want to have a $25 analysis of the transmission oil by Blackstone labs because they'll be able to determine if it's breaking down due to wear, age, temperature, and many other variables. I have my engine oil tested every change. It's one of the best ways to truly know the health of your vehicle.
The sample collection kit is free but the analysis is $25 and they'll do any viscous lubricant in the car. Great for difs also!
http://www.blackstone-labs.com/
Old May 3, 2012 | 08:19 AM
Thanks for the fast replys. The fluid has been in for just over 3 years @_@ is that bad? What is the recommended time/mileage? What fluid and weight should i put in? Thanks again guys.
eric
Old May 3, 2012 | 11:30 AM
dwight's Avatar
Clutch uses DOT3/4 brake fluid. Transmission uses Honda MTF.
https://www.s2ki.com/s2000/topic/565...id-change-diy/
Old May 3, 2012 | 02:56 PM
Paul Boz's Avatar
eric
Dang, I'd say you're DEFINITELY in need of a transmission oil change if you've been driving it hard like that for that long (purely an assumption on my part). I usually aim for every 20,000 miles or 18 months due to the stresses I generally put on the car. My z32 TT gets its gear oil changed every 10k but it's mostly used for track days etc. I bet that stuff is going to stink like hell when you drain it. I would absolutely recommend doing your diff oil as well, as that's probably so nasty it'll make you throw up when you drain it. Don't get it on your clothes or you may as well throw them away.
Old May 3, 2012 | 04:06 PM
s2000maniac's Avatar
3 years? my goodness!!!
Old May 3, 2012 | 10:09 PM
Revs 2 9K's Avatar
i also go 10k in between changes
Diz
Sep 20, 2010 08:59 PM
ian05s2k
Jul 18, 2006 06:20 PM
00SType
Jul 19, 2004 04:16 PM
kush only
Jun 24, 2003 03:04 PM
RUGBY
Jul 8, 2002 11:45 AM
