Trans Fluid Fill Bolt stuck
Old Dec 25, 2017 | 02:10 PM
AZS2KDancer's Avatar
Default Trans Fluid Fill Bolt stuck
I'm trying to change my tranny fluid, but I'm having trouble getting the tranny fluid fill bolt loose. I've tried hitting the ratchet handle with a rubber mallet, but it still won't budge. The only cheater bar I have is a 1/2 inch, and that does not fit the 3/8" 17mm socket.
Any advice?
Old Dec 25, 2017 | 02:19 PM
Midnightdennis's Avatar
Buy the right tools? Hit the gym? Lol
Old Dec 25, 2017 | 02:22 PM
17mm socket on the bolt. 3/8" drive. Trying to snap it instead of a slow burn. It's not budging.
Old Dec 25, 2017 | 02:47 PM
HarryD's Avatar
It's only supposed to be ~30 ft-lb; I'm not sure what to tell you. I usually hit the ratchet with my hand to break it loose, no sweat.
https://www.s2ki.com/forums/s2000-un...ge-diy-565855/
Old Dec 25, 2017 | 02:57 PM
Boy! Do I feel stupid. I was trying to open the wrong bolt. It was far more than 33 ft lbs, and much longer than I recalled. Yet is also had red paint on it. I put it back in and corrected myself. The fill bolt came off with no trouble. I wonder which bolt I took out first?
Old Dec 26, 2017 | 07:10 AM
windhund116's Avatar
Did it look like the big threaded hex-plug in the middle of this photo? My guess is the plug has something to do with access &/or assembly of the transmission. As long as it didn't come off, you are prolly okay.
Old Dec 26, 2017 | 06:19 PM
Singh_snisen's Avatar
That hex bolt is the sealing bolt that is torqued to 51 ft lbs.
Old Dec 26, 2017 | 07:10 PM
I took out a bolt that is in front of that large hex bolt. It's back in, but may not be torqued down enough.
Old Dec 26, 2017 | 07:29 PM
I think it might have been a lower transmission mounting bolt. It is fairly long and looks like the bolts on page 13-10 of the 2000 - 2004 Service Manual. Yet there is no torque value that I see for those bolts.
Old Dec 28, 2017 | 09:27 AM
jyeung528's Avatar
torque it down some more.
dan_uk
Feb 10, 2009 04:47 PM
daygolove
San Diego S2000 Owners
Sep 18, 2007 06:25 PM
daygolove
Sep 18, 2007 05:53 PM
mgebers
Apr 26, 2007 11:16 AM
Jsmply
Nov 22, 2006 03:29 PM
