Transmission
Old Feb 13, 2006 | 07:17 PM
s2000from canada's Avatar
Default Transmission
Hi Guys, I took my buddy who is a mechanic for a ride in my 2000 S2K. It has 50k miles on it and just got new plugs via the recall.
There is some noise (loose metal...gargling sound) that he says is coming from the transmission. He thinks it the input shaft bearings on the tranny are bad. Has anyone experienced this before? Can these be replaced without having to replace the whole tranny. I just drove it 1000 miles this weekend with no issues other than the noise coming from the tranny area.
Thanks
Old Feb 13, 2006 | 07:36 PM
4bang6's Avatar
does it sound like a loose washer on a bolt, kind of high pitched, I have this sound I wander if it's the same, nobody seems to figure out where it is coming from
I'm at 58,000 miles
Old Feb 14, 2006 | 06:14 AM
The sound is like a can filled with marbles. It is louder in the cockpit than standing near the engine area. It gets faster and louder with throttle.
My mechanic suspects its coming from the tranny. Input bearings are worn/loose
Old Feb 14, 2006 | 08:50 AM
cdelena's Avatar
I don't recall any posts about transmission bearing failures, but there are plenty regarding noise from the clutch. Unless your bud is very familiar with an unusual S2000 issue I would guess he is off base on this one. Get with an S2000 mechanic to see, but the guess would be FD noise that is common in the cars, especially ones with the early clutch parts.
Old Feb 14, 2006 | 10:39 AM
Thanks cdelena...I have booked a test drive with a local s2000 specialist. I was a little skeptical about his diagnosis since I found few, if any issues regarding these failures in the S2K.
I'll update the post later
Old Feb 14, 2006 | 02:49 PM
Race Miata's Avatar
To try narrow down source of problem online or with your mechanic, especially when transmission is suspected, note how the noise goes with:
- throttle on/off
- gear in/out
- clutch in/out
- engine speed/road speed
and all of the above combination.
Old Feb 18, 2006 | 06:09 AM
OK ...get this. I took the car to Speedstar. My local S2000 specialist to find out what this noise is that my mechanic and the dealer couldn't figure out. It turned out that the A$$ who changed the oil last dropped the oil filler cap and it landed on top top the tranny bay. Instead of getting it out he just replaced it with a new one. THAT's what was making the aweful noises near my tranny. After several test drives and jacking the car up several times problem solved. The tech Albert needed to drop the tranny just to get to the part and only charged me $50! If you live in the GTA then Speedstar is the place to repair or upgrade your S2000. Honest and good techs are hard to find!! These guys know how to treat customers!
Old Feb 18, 2006 | 07:24 AM
rad23racer's Avatar
I have the same noise issue...
Already found one oil cap.
I wonder how many more are in there?
MMIISMM
Apr 14, 2016 08:41 AM
warpspeed
Jul 3, 2007 10:18 PM
nureulwihaesuh
Sep 1, 2005 05:54 PM
FormerH22a4
Sep 22, 2002 03:05 PM
Orosie's S2K
Jun 2, 2001 09:57 AM
