Transmission/clutch issue.
Old Aug 4, 2016 | 08:50 AM
JMAnonymous's Avatar
Default Transmission/clutch issue.
So I have an 01 s2000, 124k. my clutch has the normal 1" of play that if you lightly press the clutch in it will move then stop a little from that button sensor.
Every gear seems to "notch" itself into place unless I am accelerating or rev up after clutch in and before shifting. Now my 3rd gear requires a very specific method to shift into perfectly from 2nd above 4000rpm, it will grind even during a proper h pattern shift, unless you lightly press up, let the spring pop it out of second and push up into 3rd at the perfect angle. It has been in 2 accidents that were of minor damage but at decent speeds. There is also black gunk at the bottom of the master as well as inside on the rod where it goes through the firewall, that would be high temperature grease right? Or is that the same gunk from the master cylinder? I'm going to replace my master and slave cylinder, possibly clutch lines, get under the car and check the bolts that mate trans to engine, if all else fails I will attempt rod/free play adjustment. Any other suggestions? I regressed the shifter and did transmission fluid at 110k
Old Aug 4, 2016 | 09:20 AM
Car Analogy's Avatar
This has to be the most common S2k issue. Rough shifting due to incomplete clutch disengagement.
Start with just gravity bleeding the clutch hydraulics, and adjust clutch rod. Bottle of brake fluid is way cheaper than mc and slave, parts you probably dont need.
Follow the gravity bleed diy carefully. Make sure to clean out the mc reservoir, then to prevent future issues every other oil change, change the fluid in the mc (turker baster).
Sent from my SM-G920P using IB AutoGroup
Old Aug 4, 2016 | 01:12 PM
Slowcrash_101's Avatar
Only true way to bleed the clutch hydraulics is the Billman way, which is the motorcycle mechanics's way, which is to get the bleeder on the clutch to point straight up and just gravity bleed it. Use up a whole little bottle of Valvoline dot 3/4 that you buy at the autoparts store. Make sure you cover the fender and painted surfaces before you start playing with break fluid unless you like stripped paint. If any gets on you have about 60 seconds to wash it off with water before the fluid starts damaging the paint.
Old Aug 4, 2016 | 01:15 PM
B serious's Avatar
https://www.s2ki.com/s2000/topic/115...#entry24025311
Old Aug 5, 2016 | 10:29 AM
So I adjusted the rod for an hour and after letting it fall out and having a fun trying to learn well I got my shifting issue resolved. The car feels like it wants to pull quite a bit as well. BUT, now there is a jumpy feeling and a clink clank noise like maybe the engine or transmission mounts are bad? It feels like the car is trying to move but sometimes sputters for a slight second. It alsp happens when i let off the throttle I had this issue before fixing it as well. Any info?
Old Aug 5, 2016 | 10:47 AM
Jumpy feeling? When does the car make these noises, or symptoms. If you're talking about occasional hesitation putting around town, get in line. It seems to be a common problem in the heat.
Old Aug 5, 2016 | 04:19 PM
I hear the clinking and clanking happening when engaging 1st from a stop, or if I let off the throttle a little. going say 20, let off the throttle, clink clink clink, rolling at 20.....19.....18.....17 then if I slowly go back into the throttle instead of braking to a stop, clink clink clink and kind of a small rock back and forth as your accelerating. It could just be that's how the car is, I have had the sound since the day I got the car. It really sounds like it's coming from the back by the transmission/diff during throttle engagement, but I have no idea.
Old Aug 6, 2016 | 07:54 AM
Have you checked your diff mounts?
Old Aug 6, 2016 | 10:33 AM
Nope, but I will have to have a look. I hear the same clink in the front occasionally so I'm guessing all motor trans diff mounts, or loose trans to engine bolts.
_2K1S2K_
Jul 22, 2013 08:05 PM
amirgho
Aug 23, 2012 08:22 PM
stwoki
Feb 24, 2011 07:15 AM
djohnston
Jan 30, 2002 10:25 PM
Howie
Mar 27, 2001 03:19 PM
