Transmission fluid
Old Jun 25, 2015 | 01:51 PM
Gotpepsi's Avatar
Default Transmission fluid
I been noticing that it's getting harder to shift in to first gear. It may be because I am in a hurry, but often first gear seems to hit a wall. I have to shift into second first then to first. Takes me less then a second but I think I need to change the fliud. I changed it last year at 95-98k? The car has 110,000 now. I looked on the manual, it stated that transfluid should be changed at 60k intervals and diff fluids at 15k intervals. Opinions?
Old Jun 25, 2015 | 02:11 PM
windhund116's Avatar
Maybe change the clutch hydraulic fluid, too.
Old Jun 25, 2015 | 02:14 PM
Gotpepsi's Avatar
The clutch fluid is pretty good I believe. I usually just suck the old stuff out with a syringe and replace it with new fluid ever 6 months or so. It gets black pretty quick.
Old Jun 26, 2015 | 06:32 PM
zeroptzero's Avatar
Tranny and diffs shear fluids over time and the fluid loses viscosity the longer it is in use. MTF2 fluid is pretty thin to start out with. I find the OEM MTF2 fluid starts to lose effectiveness after 8,000 miles. I change it once a year regardless of miles, a bit of overkill but my tranny shifts perfectly at all temperature conditions, at 65k miles it feels like it just came from the factory. Tranny fluid changes are cheap maintenance.
Old Jun 26, 2015 | 08:58 PM
Gotpepsi's Avatar
I just changed it today, cost me 18 bucks. The fluid was pretty dark when it came out (well compared to the new fluid). Thanks for the reply. Feels alot better. The fluid had about 9-12 k on it.
Old Jun 27, 2015 | 07:26 AM
Chuck S's Avatar
The shifting is better?
Consensus here seems to be to change the gearbox oil every other engine oil change. A couple of MTFs seem to work well (some GM has been mentioned) but the Honda-branded oil is easy to find. Messy job for me under the car!
-- Chuck
Old Jun 27, 2015 | 07:55 AM
jkelley's Avatar
-- Chuck
Um, I really don't think I've heard anybody say that they do this? Unless their S's are weekend-only cars and only get 5k mi/yr or something. But otherwise I think the most frequent "common" interval is once per year, and that's typically for a daily driver.
Old Jun 27, 2015 | 05:15 PM
Gotpepsi's Avatar
I think every other oil change is a bit too much. But the shifting is alot better. Feels great now actually. It has not gotten stuck in two days
stwokayyy
Apr 15, 2020 11:21 PM
Car Analogy
Dec 15, 2014 03:50 AM
s2kvince
Apr 10, 2009 09:56 AM
jdmjeff
Jan 11, 2009 07:38 AM
MDS2K
Oct 1, 2001 01:43 PM
