Transmission fluid change
Old Feb 27, 2005 | 04:52 PM
TwistedS2k's Avatar
Default Transmission fluid change
I changed my transmission fluid today and noticed that the reservoir started to overflow before I finished dumping the second quartz into the reservoir. I stopped filling the reservoir and noticed that there was a little bit of fluid left, so it did not seem like it would take the whole 2 quartz to fill up the reservoir. Is this true? I hope I've added enough fluid. The car seems to be shifting ok without any problem.
Old Feb 27, 2005 | 05:23 PM
xviper's Avatar
The tranny only takes about 1.7 qts. You only put in as much as won't fall out when the car is level and the fill plug out. My "How To" in the FAQs in Technical shows you how to know when the tranny is "full".
Old Feb 28, 2005 | 02:35 PM
hpark's Avatar
jdmjeff
Jan 11, 2009 07:38 AM
demitri
Sep 5, 2005 08:37 PM
BlackJoker
Aug 25, 2005 10:04 AM
p0pe
Jun 15, 2005 08:42 PM
