Transmission Issues.
Old Jan 5, 2002 | 02:28 PM
Prolene's Avatar
Default Transmission Issues.
I noticed some metal particles on the transmission magnetic drain plug when I drained the few thousand mi old Redline fluid today. This is not surprising considering the occasional but rare botched shift, and parhaps a track session. A magnetic drain plug may be helpful to prolong transmission life or at least prevent additional wear. If the Spoon plug package is purchased, I used the longer magnet for the transmission, as both plugs would fit both trans drain and crankcase drain.
I noticed that the 'old' unopened Honda MTL I had in the garage smelled more of sulfur than the fresh Redline MTL. Honda MTL may be the best for S2000 application. I think Cdelena advocates Honda MTL. Fresh MTL may allow better shifting than as to whatever brand is used, as well.
Old Jan 5, 2002 | 03:03 PM
bayarea408's Avatar
prolene,
did you notice anything after you changed the tranny fluid?
how did you like Redline?
Old Jan 5, 2002 | 03:20 PM
spider's Avatar
I believe the stock tranny drain plug is also magnetic.
Old Jan 5, 2002 | 07:03 PM
cdelena's Avatar
The diff plug is magnetic but I don't think the transmission plug is. I have the Spoon set but they are not yet installed.
Old Jan 5, 2002 | 07:45 PM
Prolene's Avatar
Originally posted by bayarea408
prolene,
Redline initially made the shifts feel smoother, but after a few thousand miles seemed not as smooth, and I had a grind on a particularly hot day. I changed the fluid and noticed it was really no longer the reddish color.
I believe Honda's MTL and Redline are quite different (color, being one obviously ), with the Honda's at least with more of a scent of differential fluid. Whether this is better or not, I am not sure. It's just that for me, Redline wasn't 'perfect', and Honda's specs for fluid seems like its own mtl fluid would fit the bill the best. Maybe not perfect, but perhaps better or at least as good as anything else.
Spider, neither of the the stock transmission plugs are magnetic, as Cdelena stated.
Old Jan 5, 2002 | 07:49 PM
RT's Avatar
RT
The tranny has a good sized magnet inside it.
Old Jan 5, 2002 | 07:57 PM
Prolene's Avatar
Interesting. It missed several particles the Spoon plug caught first, though.
Old Jan 6, 2002 | 01:14 AM
RT's Avatar
RT
[QUOTE]Originally posted by Prolene
[B]Interesting.
Old Jan 6, 2002 | 04:41 AM
cmnsnse's Avatar
The speed sensor also picks up some metal stuff
Old Jan 6, 2002 | 08:11 AM
spider's Avatar
How do you clean that magnet then? No need, I guess?
