Transmission noise
Old Sep 19, 2011 | 11:33 AM
rambo36's Avatar
Default Transmission noise
I have a annoying sound coming from my transmission.
The sound appears at all speeds.
I did remove de transmission and clutch and i discovered the clutch hat the clutch buzz problem.
So the clutch gets replaced only my transmission makes a sound.
Could it be a bearing in the transmission?
Look at the movie below specially the first part were i drive slowly.
[media]http://www.youtube.com/watch?v=h7h6-8RNjVY[/media]
Old Sep 19, 2011 | 05:17 PM
rmmlotus's Avatar
Have the same noise sounds like a pachinko machine............... mine makes the noise in gear, out of gear, clutch in or clutch out...
Hope someone can tell us the fix..........
Old Sep 19, 2011 | 06:45 PM
Soul Coughing's Avatar
Sounds like a bearing, more than likely the tapered roller bearing on the secondary shaft. Does it make a noise when you are at a stop with the engine idling and the foot off the clutch pedal? Or does it make a noise whenever you're moving, clutch in or out?
Old Sep 20, 2011 | 12:15 AM
rambo36's Avatar
Excacly the sound only apears wen i am moving so i suspect that it is a bearing of the secondairy axle because this one is the only one that stands still when you stop.
But at the same time i have a clutch buzz.
I can get a new transmission for 350 dollar with 13000 miles on it so i am not sure what to do.
If you listen to the sound on the video you would say its a bearing.
Old Sep 20, 2011 | 07:14 AM
S2000Guatemala's Avatar
I have the same issue, here´s the solution.
https://www.s2ki.com/s2000/topic/409.../#entry8228551
alexisthemovie
Sep 13, 2009 08:27 PM
skeithr
Oct 23, 2008 06:55 PM
JAPCAB
Sep 14, 2007 02:27 AM
FOSCshadow
May 27, 2006 11:00 AM
daltb84
Nov 27, 2003 07:06 AM
