Transmission not smooth
Old Oct 12, 2016 | 10:44 AM
Xeon's Avatar
Default Transmission not smooth
Hi guys my 2002 ap1 is very rough shifting into 2nd gear and I have changed my trans fluid a month ago with Honda mtf maybe my clutch needs adjusting idk it just feels like I have to force it into 2nd gear sometimes even 1st gear is a bit hard to get into all the other gears are fine
Old Oct 12, 2016 | 10:53 AM
GSteg's Avatar
Have you tried to replace and bleed the clutch fluid?
Old Oct 12, 2016 | 11:10 AM
Xeon's Avatar
Yes I have done that
Old Oct 12, 2016 | 11:11 AM
Xeon's Avatar
I was thinking to try gm/acdelco synchromesh friction modified what do you guys think maybe it's the tranny fluid
Old Oct 12, 2016 | 11:30 AM
Xeon's Avatar
Or maybe I should adjust the clutch pedal rod to go in a bit more when I press the clutch in
Old Oct 12, 2016 | 11:41 AM
GSteg's Avatar
Adjust the rod only to remove the slack, but under no circumstance should it be adjusted beyond that.
Old Oct 12, 2016 | 11:46 AM
Xeon's Avatar
Yep
Old Oct 12, 2016 | 03:23 PM
Xeon's Avatar
Just adjusted the clutch rod and it fella much better I am Gona adjust the pedal sensor so the pedal comes up a bit more just to make sure the clutch is fully engaged
Old Oct 12, 2016 | 04:25 PM
Car Analogy's Avatar
Note that you'll need to readjust rod whenever (after) you adjust pedal height.
Old Oct 13, 2016 | 10:21 PM
Xeon's Avatar
Yeah I raised the pedal a bit and extended the rod a bit the bite point is a bit higher but since the rod goes in deeper when I press the clutch pedal I have smoother shifts
