transmission separation problem
Old Apr 7, 2014 | 04:21 PM
ktwenty's Avatar
Default transmission separation problem
I'm trying to separate my transmission from the engine but it only separates about 8mm @ the top an sides, btw I removed all bolts and clucth release fork. I have been reading about input shaft binding, any recommendations please?
Old Apr 8, 2014 | 05:35 AM
ktwenty's Avatar
any suggestions?
Old Apr 8, 2014 | 05:52 AM
chris_barry's Avatar
Remove the clutch slave cylinder. Pull the clutch fork outwards, step back to avoid the gearbox dropping on your foot.
The S2K has a pull clutch. The clutch fork pushes into a slot on the thrust bearing which is pulled through the pressure plate.
Old Apr 8, 2014 | 05:56 AM
Mr`revto9k's Avatar
did you remove the top starter bolt all the way?
ktwenty's Avatar
I already removed the slave cylinder and clutch fork pulled all the way out
Old Apr 8, 2014 | 05:57 AM
ktwenty's Avatar
Yup all bolts out starter is on the ground
Old Apr 8, 2014 | 06:02 AM
ktwenty's Avatar
I really think it's some sort of binding taking place so gonna try some penetrating oil through the opening where the fork passes directed on the input shaft
Old Apr 9, 2014 | 12:07 PM
ktwenty's Avatar
Problem solved guys
Old Apr 9, 2014 | 05:08 PM
s2klariat's Avatar
Originally Posted by ktwenty
Problem solved guys
Don't leave us hanging, what did you do to get it out?
Old Apr 10, 2014 | 10:21 AM
ktwenty's Avatar
It was a binding issue just took some time and effort to pry free
dbzerk
May 21, 2023 02:36 PM
Rob@ReidyRacing
Aug 9, 2017 04:34 PM
silvermonster
Jul 16, 2012 09:50 AM
splatter85
Apr 14, 2010 11:55 PM
emerlin
Aug 25, 2006 08:33 AM
