Transmission whining only when accelerating on 4/5/6 gear?
Hello forum,
I did extensive searches but did not really find a solution for my specific whining:
It only happens on 4/5/6 gear maybe the exhaust is too loud on other gears. It only happens on acceleration, it went away when I let off the gas / press the clutch. When the car in neutral it does not whining at the same rpm, regardless of wheel speed.
Trans fluid is new.
So it basically rules out the output shaft of the trans, the diff, and the engine. But then there is only clutch and the input shaft of the transmission left. But I never saw other reports whining on these parts.
I'm so confused, hopefully I can find an answer before I pay $$$ to open that trans.
Trans fluid is new.
Same whining noise, clutch pedal in or out?
Thanks!
Thanks!
Definitely does NOT sound like output shaft bearing, good call! Have you changed diff fluid lately?
Also without acceleration there is no whining, even clutch engaged while cruising. I think this rules out the diff.
