Trunk Latch Assembly
Old Feb 23, 2013 | 12:09 PM
ewcollins's Avatar
Default Trunk Latch Assembly
I can only open the trunk on my 2000 S2000 by using the key.
Is it possible to repair the latch assembly (74851-S2A-003) or do I have to buy a new one?
Will it be easy to replace the latch assembly myself?
Old Feb 24, 2013 | 05:43 PM
Soof's Avatar
It doesn't open maunually with inside release ???
Old Feb 24, 2013 | 08:57 PM
vasquezgno's Avatar
i hAVE THE SAME PROBLEM
Old Feb 25, 2013 | 07:19 PM
Utah S2K's Avatar
The trunk circuit is also connected to the keyless door lock control unit. Q1- Does your kekless lock function work? If not check fuse #26, it's Located under the dash on the main fuse panel. Right side second fuse down. If door lock works it's either the trunk switch or trunk solenoid. Frankly I have seen this mode twice and both cases were fixed by re seating the connector for the trunk solenoid. 3 pin rewarded next to the trunk latch. Obviously came loose during trunk opening nag and closing.
Utah
Old Mar 1, 2013 | 11:47 AM
Prokaw875's Avatar
I am having the same issue too. The keyless entry works fine, and the trunk opens with the key in the trunk no issue. Its only the button for the trunk inside the glove box that wont pop the trunk. Was working one day... and wasnt the next. Physically the button feels normal, not like it is snagged or anything.
Old Mar 5, 2013 | 09:22 AM
ewcollins's Avatar
That is correct. As I said before, "I can only open the trunk on my 2000 S2000 by using the key."
Old Mar 5, 2013 | 09:27 AM
ewcollins's Avatar
Utah
The keyless lock will only unlock the doors, but not the trunk. The inside release (button inside the glove box) does not work either. There does not seem to be any loose electrical connection to the latch assembly.
Old Mar 5, 2013 | 10:49 AM
Stratocaster's Avatar
Does the button work with the key in the ignition, turned on?
Old Mar 9, 2013 | 11:04 AM
ewcollins's Avatar
The inside release (button inside the glove box) does not work even with the key in the ignition and the engine turned on.
Old Mar 9, 2013 | 01:31 PM
s2cho's Avatar
i had this problem and i just pulled the wires that are on the left and it started to work agian lol
