TSB's regarding the wheel click
Old Mar 30, 2006 | 10:33 AM
bills2k_2001's Avatar
Default TSB's regarding the wheel click
Hope someone can help. I have the clicking problem in MY01, right rear. I've re-torqued the wheel nut twice, and the clicking came back after about 2 weeks. I've talked to a dealer that stated they've never heard about this problem. I found a post somewhere that listed:
"Service Bulletin 011201 Sequence Number: 627 Clicking Rear replaced Hub Nuts"
I also found on the NHTSA Site:
" Service Bulletin 1204 Item No. 10018085 Power Train:Axle Assembly"...Rear Axle Creak or Grunt Noise at Low Speeds.
I was not able to find either TSB on this site. I really want to get this taken care of before a track day in June. Any help?
The car only has 16,000 miles on it. Thanks!
Old Mar 30, 2006 | 11:37 AM
JDMwhore's Avatar
It's not a offical TSB
Old Mar 30, 2006 | 12:25 PM
dbzerk's Avatar
I've just replaced my hub and bearing.. that fixed the problem...
Old Mar 31, 2006 | 02:54 PM
did you have the dealer do this or were you able to do it yourself?
Old Mar 31, 2006 | 03:04 PM
Slows2k's Avatar
[QUOTE=JDMwhore,Mar 30 2006, 03:37 PM]
Old Apr 1, 2006 | 01:05 AM
RACER's Avatar
You may want to apply grease to the driveshaft splines where they spline to the hub in addition to replacing the nuts, applying grease where the nut contacts the hub and re-torquing to the new torque.
Old Apr 1, 2006 | 05:26 PM
dbzerk's Avatar
I did it myself.. but i had access to a press
Old Apr 3, 2006 | 07:14 AM
omg516's Avatar
are there any other sounds associated with the click? i get it once in a while and i was wondering what that was.
Old Apr 3, 2006 | 03:16 PM
dbzerk's Avatar
When it gets worse you get a 'metallic moan' this means your hub is ruined and you will need to replace the hub and bearing..
Get that hub nut tighten to 220 ft lbs and all will be good if it isn't too late.
cdelena
Aug 21, 2013 05:27 PM
gbaker
Jun 27, 2012 04:07 PM
2k_s2k
Sep 2, 2011 07:06 PM
Elistan
Jun 5, 2007 08:27 PM
SLstone s2k kid
Dec 21, 2006 11:07 PM
