Turbo Installation Question
Old Aug 2, 2003 | 02:23 PM
fperra's Avatar
Default Turbo Installation Question
I'm just about finished with the install of my UR turbo, but I've run into a snag. Wondering if anyone can help. My problem is this: The turbo has water cooled bearings, and I need to find a source for the water. The instructions call for routing the water from the outlet on the front of the intake manifold by the throttle body. My problem is that I have a Hondata gasket that blocks this water passage. I'm thinking of using the water bypass hose on the front of the block that goes to the oil cooler. My question is, does this line have a constant flow of water?
Old Aug 2, 2003 | 07:01 PM
fperra's Avatar
Old Aug 2, 2003 | 09:27 PM
xviper's Avatar
Yes, it does, but if you tap into that line, your oil cooling jacket will not get the water it needs to do the proper job of cooling the oil.
Old Aug 3, 2003 | 03:33 AM
fperra's Avatar
Thanks. I'll run the water from the outlet side of the oil cooler to the turbo bearing inlet and from there, back to the block where the oil cooler outlet would normally go.
Old Aug 3, 2003 | 08:52 AM
S2000_Europe's Avatar
fperra i know it a bit off topic but I need the information ASAP
did you get any disk with to progrm the Emanage? I got only a CD with the instructions to install the Turbo
thanks
Old Aug 3, 2003 | 11:04 AM
fperra's Avatar
The software is sold as a seperate package.
Old Aug 3, 2003 | 11:06 AM
i ma not talking about the support tool, is about the UR settings that is suppose to be uploaded in the Emanage.....
Old Aug 3, 2003 | 11:07 AM
about installation pm Reignman he has installed the turbo recently
Old Aug 3, 2003 | 11:25 AM
fperra's Avatar
The emanage supplied by UR is preprogrammed by them. Supposedly, it is plug and play. I got nothing else but the emanage and the harnesses. I'll be using the AEM ems instead of the emanage in any case.
Old Aug 3, 2003 | 11:28 AM
could you please download the program and send it to me? my Emanage is "empty"....
