turbonetics delta watsegate keeps breaking
I have an s2000 turbo the kit is totaly custom and everything
works great except for the wastegate. i have had the turbo on my car for about 1year and i have had to repalce the wastegate 2 times, for some reason the spring that reg. boost
keeps breaking and i don't undersand why.
I/We have had recurring problems with Deltagates, and no longer use them on anything unless specifically requested to do so. Even then I will try to talk a customer out of it. Not only do the actuator rods break, but the part of the body that the valve seats against will corrode and pit, causing boost leakage all the time. Tial manufactures a high quality unit that is a direct bolt-in replacement for a Deltagate, and it is a bargain at $300. Deltagates do make good doorstops, though.
Tracy, I have a Deltagate on my MR2 and I am kinda scared now! I love the Tial product that comes with the kit but the flange is completely different.. which wastegate has the same flange as the Deltagate? (This is the Turbonetics Deltagate you guys are talking about, right??)
Chris
Chris
I think I'm going with tial wastegate although I always used a turbonetics delta wastegate in the past and never had a problem but for this to happen twice in less that a year is someting i can't
explain
explain
Originally posted by s2000turbo18
As far as speedcraft, i would but my car up against any s2000 with a speedcraft kit and I garantee that i will beat it in any aspect. (dyno or track)
BTW, deltagates are also well known for their boost creep.
but really.. you need to quantify your claim... running same amount of boost? etc etc.
