Uneven drop? Why? i checked everything..PLS HELP
Originally Posted by tunerjetta29,Feb 16 2006, 09:13 AM
Why dont you actually measure the ride height correctly (not with your fingers) and then adjust the coilovers to make it correct. Just because you measure and make the coilovers the same length doesnt mean it will sit level when they are installed, there is a different amount of weight on each corner of the car, which will cause the car to sit uneven.
Originally Posted by Smokings2K,Feb 16 2006, 03:07 PM
Thanks for everybody's feedback here, i finally solved the issue. My problem was, i didnt preload the coilovers after installation. I just did them today and everything looks perfect to me...
Originally Posted by tommylam16,Mar 6 2006, 05:02 PM
Since you just preloaded your suspension recently, can you help me with my coilover? I have the Bilstein PSS9 (not sure what you have) for over a month now, uninstalled. I was wondering how do I preload them. The instruction say just let the car down before you tighten any rubber mounts. This seems pretty straight forward. It doesn't say to preload them too any specific distance. Are there any other tips you or anyone can offer me before I attack this job.
Preloading springs means you got to adjust the height of the spring relative to the upper spring mounting point. Hence preloading. You are loading/unloading the spring tension. More or less you are "tensioning" the spring.
Preloading the suspension means you are adjusting the upper A-arm and the lower control arm (LCA) to "ride height"
To preload the suspension measure the the distance from the center of the hub (middle of "H" emblem) to the fender. Be sure the upper A-arm bolts are loose. Now jack the car up, take the wheels off, loosen upper A-arm, put jack under the LCA and jack up to "ride height" and tighten 2 bolts on the upper A-arm. This is how I preloaded my front suspension.
Anyone feel free to correct me if I am wrong.
Originally Posted by SOHCmyDOHC,Mar 6 2006, 05:50 PM
Preloading the springs is different from preloading the suspension.
Originally Posted by tommylam16,Mar 6 2006, 10:22 PM
so, first we jack up the car to loosen the upper A-arm bolts (2 of them). Then we lower the car to measure ride height. Then we put it on jack stands to jack up the LCA to the distance that we meared? Is this right? How come the instructions that came with my Bilsteins didn't say anything about preloading the suspenison. All it said was "all rubber mounted struts/shocks absorbers must be tighten after the vehicle is let down to the ground." Are they talking about just the nut that holds the shaft of the damper in place? Thanks guys for any inputs.
What I did is jack the car up until the frame came off the jackstand and then lowered it until it rested back on the frame and matched my measurements. Then I tightened the 2 bolts. Not perfect but with my limited resources it will do.
As far as preloading the suspension it states it in the Helms manual to preload the suspension before tightening the bushings.
