Updated TSB List
Old Jun 3, 2005 | 12:06 AM
  #51
Moemers's Avatar
they made the s2000 in automatic? wtf
Old Oct 30, 2005 | 01:29 AM
  #52
Tech7427's Avatar
here is a nice list straight from All-Data..yes im a noob to the site..and hopefully picking up my s2k on monday...trying to sell my integra to pay for this beauty..
anyway..
Number Date Title
01-037 07/05/2005 Body - Convertible Top Rattles/Windnoise
SN050600-011 06/01/2005 A/C - Heater Blows Cold Air, A/C Blows Warm Air
01-100 05/13/2005 M/T - Pops Out of 4th Gear
SN050508 05/01/2005 Exhaust System - Catalytic Converter Noise
SN050506 05/01/2005 Wind Noise - Simple Way To Replicate
SN050416 04/01/2005 Engine - Falters/No Power/Won't Rev Over 7000 RPM
SN050407 04/01/2005 A/T - Do Not Remove Torque Converter From Mainshaft
SN050418 04/01/2005 Body - Plastic Body Clip Removal Tips
SN050314 03/01/2005 A/T - Fixing Banjo Bolt Leaks
SN050316 03/01/2005 Engine Controls - Clearing DTC's
SN050311 03/01/2005 Windshield Wipers - Blade Care & Replacement
SN050202 02/01/2005 A/T - Avoiding Fluid Contamination
SN050206 02/01/2005 Engine Controls - DTC P0172
SN050215 02/01/2005 Audio System - Never Play CD's With Adhesive Labels
01-023 01/25/2005 Engine Controls - Updating ECM/PCM Software
SN050105 01/01/2005 Suspension - Creak/Grunt From Rear At Low Speeds
SN050109 01/01/2005 Engine - Oil Recommendation GF-4 Standard
04-073 12/02/2004 Engine Controls - Hesitation on Hard Acceleration
SN041204 12/01/2004 Fuel Filler Cap Adapter Available For Testing Emissions
SN040915 09/01/2004 Driver's Air Bag - Replace Torx Bolts Properly
SN040903 09/01/2004 Popping From Front Wheel Upper Control Arm Mount
00-064 08/03/2004 Body - Deformed Windshield Moulding
02-052 07/16/2004 Restraints - Occupant Detection Initialization
03-014 06/01/2004 Body - Convertible Top Cover Snaps Broken
88-023 03/19/2004 Battery - Testing Procedure
SN040310 03/01/2004 ABS - Grunts When Doing A Self-Check
SN040308 03/01/2004 M/T - Grinding At Upshifts When Cold
98-011 02/20/2004 Keyless Entry - Remote Transmitter Information
04-009 02/17/2004 Computers/Controls - HIM Module Updating
SN040215 02/01/2004 ABS DTC 51 Or 53 - Diagnostic Tip
SN040211 02/01/2004 Speedo/Odometer Read Excessive Speed & Distance
SN040214 02/01/2004 Headlight Adjustments
SN040203 02/01/2004 Clutch Pedal Is Noisy or Feels Notchy
SN040111 01/01/2004 Engine Oil Recommendations
SN031107 11/01/2003 Blower (Heater) Motor Gets Hot and Blows A Fuse
SN031106 11/01/2003 Air Fresheners - Bad News For Paint Or Plastic
SN031007 10/01/2003 M/T - Hard To Shift Into 1st Gear, Grinds Into Reverse
03-062 09/16/2003 Interior - Seat Belts Slow to Retract
SN030915 09/01/2003 Suspension - Drifting & Pulling At Highway Speeds
SN030813 08/01/2003 Interior & Exterior Trim - Tool To Make Removal A Snap
98-018 07/22/2003 Drivetrain - Revised CV Joint Boot Band/Installation
SN030707 07/01/2003 Catalytic Converter - Rotten Egg Smell
00-088 06/03/2003 Brakes - Brake Disc Refinishing Guideline
SN030502 05/01/2003 Clearing DTCs & Setting ECM/PCM With The HDS
01-008 04/29/2003 Body - Driver Window Won't Go All The Way Down
00-049 04/29/2003 Antitheft System - Type 2 System Operation/Programming
03-023 04/01/2003 Body - Convertible Top Creaks/Pops/Rattles on Rough Road
SN030407 04/01/2003 DTC's P0133 & P0420 Set After Manual Trans R&R
03-020 03/29/2003 Engine Controls/Emissions - OBD II DTC's & Monitors
SN030205 02/01/2003 SRS - Indicator ON with No SRS DTC Set
03-001 01/28/2003 Emissions/Engine Controls - MIL ON/DTC P1457 (EVAP)
02-065 11/26/2002 Body - Convertible Top Won't Open Properly
02-063 10/29/2002 Drivetrain - Vibration From Rear on Acceleration
02-046 07/30/2002 M/T - Difficult Reverse/5th Gear Selection
02-042 07/10/2002 Campaign - Spark Replacement
00-054 11/27/2001 M/T - Buzz/Rattle on Deceleration
01-029 05/01/2001 Engine Controls - DTC Capture and Downloading
01-038 03/27/2001 Convertible Top Cover - Comes Loose
00-099 12/19/2000 Wiring Terminal - Repair Instructions
00-089 10/31/2000 Supplemental Restraint System - Inspection
00-083 10/31/2000 Heater Unit - Water Drips Onto Passenger's Carpet
00-063 08/01/2000 Special Tool - Chassis EAR™, Diagnostic Tool
96-012 07/05/2000 A/C - System Performance Testing
Old Nov 8, 2005 | 10:03 PM
  #53
Inlands2k's Avatar
so lets say that i just bought a used 2000 s2k.... would i be able to take it to the dealership and get the TSB's all worked out? if so what do i need to take and show them? any info would be appreciated greatly. im new to the honda world! help is needed.
Old Nov 9, 2005 | 04:07 AM
  #54
Slows2k's Avatar
A 2000 model is well out of warranty. You won't be getting anything done without a fight. Not all cars have the problem listed in a TSB.
Old Nov 9, 2005 | 11:56 AM
  #55
GDM S2K's Avatar
I recently picked up a 200- s2k and wondering how I would go about bringing the S to the dealer to have these takin care of? Should I print this out. After all I have a warranty still and i have a few things on that list
sorry i didnt read the post above
Old Nov 9, 2005 | 03:17 PM
  #56
Slows2k's Avatar
The factory 3yr/36K warranty is long expired on a 00 model. You are 2 years out of warranty, so any consideration for "goodwill" warranty repairs will depend on the DPSM for the dealer you take it too.
Be prepared for a "no"
Old Nov 9, 2005 | 03:44 PM
  #57
Inlands2k's Avatar
lol yeah i would figure but its worth a try! i mean the worst you can get is a no. right? well ill take mine when i get time and will let you guys know what they tell me! hopefully i dont get yelled at!
Old Jul 17, 2006 | 06:36 AM
  #58
S2000_Europe's Avatar
any one have the paper for the banjo bolts TSB? I did a search and looked on the library but did not find it
thx
Old Jul 17, 2006 | 03:31 PM
  #59
Chazmo's Avatar
^ Yeah, that TSB was only issued in a few countries in Europe. It was not released in the US/Can market. I definitely saw the paperwork, but it was in Dutch, if I recall correctly. I'm pretty sure there was a pointer to it in Barry's short block thread.
Old Jul 17, 2006 | 03:36 PM
  #60
Chazmo's Avatar
Found the thread:
https://www.s2ki.com/forums/index.php?showtopic=69568
