Used Engine - What to check? What to replace?
Old Sep 12, 2015 | 04:50 AM
MattP's Avatar
Default Used Engine - What to check? What to replace?
So in the hunt for a replacement engine for my AP1 I'm seeing there are two main types:
Used engines from dismantlers, importers, salvage yards. Typically have a warranty that excludes accessories, and sometimes excludes the oil pump.
Private party used engines, typically as-is.
If you had an engine with a warranty, what would you check?
I think at bare minimum it makes sense to inspect and replace the intake valve retainers and do a valve adjustment. Is it worth pulling the oil pan to check the pump?
With an as-is engine, is it worth pulling the head to check the bores, even with the added cost of a new head gasket? Is it worth preemptively replacing the bearings and rings in the bottom end? What other maintenance is worth doing?
Old Sep 12, 2015 | 09:07 AM
bgoetz's Avatar
I would pull the valve cover, inspect the retainers (replace if needed), replace the plugs, and adjust the valves. I may consider dropping the pan and looking for metal, but I personally would go no further than that. I certainly would not do rings, I don't think you can just replace the rings without then doing some type of honing, but maybe I am wrong.
I would follow up with a compression test and UOA to get a baseline and then follow up on both the first couple oil changes to see how things are going.
Old Sep 12, 2015 | 09:39 AM
99SH's Avatar
Bare minimum would be a leak-down and compression test.
If you're going to buy used and replace parts (rings, bearing, etc.) why not just rebuild what you have now?
Old Sep 12, 2015 | 09:57 AM
MattP's Avatar
Reasons not rebuilding what I have now:
1: cylinder walls in #1 scored, not sure if is under .25mm depth
2: unsure if I can find a machine shop to handle it if not too deep
3: if I hone the cylinders .25mm over, I need new pistons ($$$)
I'd totally be willing to buy just a short block as my head is totally rebuildable, but they seem to be scarce out there.
Rings do seem like overkill if the leakdown/compression looks good. Rod bearings are easy enough, but like you said, it might be overkill.
janders111
Feb 5, 2019 11:57 AM
StanW
May 4, 2015 03:02 AM
Nottm_S2
Apr 26, 2007 02:11 PM
grantedS2k
Oct 29, 2006 06:49 AM
