used keyfob programming
Old Jun 1, 2008 | 03:04 PM
s2000honduras's Avatar
Default used keyfob programming
Hi guys I lost the original key i buy n program a new key ........ now i want to program a keyfob.
I try instructions
1. turn the key on n press or hold 1 sec Lock
2. turn key off Position I make this 4 times
then get the sound cluck then push the lock again ?
i try it 3 times i cant program the controll anyone have idea?
http://handaaccessories.com/crv/KEYLESSPROG.pdf
Old Jun 4, 2008 | 12:36 PM
Sarek's Avatar
This is when I bought remotes for my wife's civic. I confirmed that they are the same for the S2000 (at least for MY02)
Programming Procedure #21031
1. Switch ignition on.
2. Within 4 seconds press lock button on the first remote transmitter for 1 second.
3. Within 4 seconds you must switch ignitions off.
4. Within 4 seconds you must switch ignition on.
5. Repeat steps 2, 3, an 4, twice.
6. Within 4 seconds press lock button of first remote transmitter for 1 second.
7. System should now lock and unlock vehicle indicate programming mode activated.
8. Within 10 seconds press lock button of first remote and unlock once.
9. Press lock button if each remaining remote to be programmed, allowing doors to lock and unlock once as each remote is programmed.
10. Switch ignition off and remove key.
11. Check operation of all programmed remote transmitters.
iceman86
Apr 9, 2020 10:38 AM
djpepsi
May 17, 2010 11:04 AM
shepp
Sep 9, 2009 09:35 AM
Ooalloems2koO
Dec 6, 2004 01:30 PM
WyattH
Nov 1, 2004 07:50 PM
