07 s2000 keyless entry programming
Old May 14, 2010 | 04:50 PM
djpepsi's Avatar
Unhappy 07 s2000 keyless entry programming
hi does anyone know how to program a 07 keyless entry i tried the 00-05 method didnt work
Old May 14, 2010 | 07:11 PM
downloader's Avatar
turn the ignition switch on press lock
turn switch off
turn switch off
keep doing this till you hear the door locks locking then press each remote lock button that you want to program.
Old May 15, 2010 | 03:08 AM
HonCBRf2's Avatar
this all has to be done within 10 seconds and all of your doors need to be closed when being performed.
Old May 15, 2010 | 10:23 PM
djpepsi's Avatar
i tried that and nothing happened at all , just a reminder that the 07 keyless entry buttons are on the key itself there is no keyless fobs
Old May 16, 2010 | 07:47 AM
rioyellows2k's Avatar
It's because the directions are wrong.
Your doors don't need to be closed. your doors can be whatever.
Get in the car.
Put the key in the ignition, and turn it to the ON position,
press UNLOCK on the remote,
turn the key to the OFF position
turn the key back to the ON position
for the final time
turn the key to the ON position,
You should hear the door lock acutuator cycle, once you hear this sound press the LOCK button on the remote, you should again hear the acutator cycle.
Turn the key to the off position. Test all the buttons on your remote.
And you clearly have the wrong key. The proper S2000 key/remote setup is a key and a 4 buttoned FOB.
Old May 17, 2010 | 11:04 AM
djpepsi's Avatar
thanks i'll try it out today
alexdog1
Oct 23, 2013 12:21 PM
shepp
Sep 9, 2009 09:35 AM
s2000honduras
Jun 4, 2008 12:36 PM
Ooalloems2koO
Dec 6, 2004 01:30 PM
WyattH
Nov 1, 2004 07:50 PM
