Using 05' 2.2 head on 03'
Originally Posted by CrazyPhuD,Feb 7 2006, 06:55 PM
The bare metal head is identical. The only differences are camshafts and springs.
OG
Originally Posted by DrDre1443,Feb 7 2006, 08:43 PM
ummm....Honda lowered the redline on the 2.2 for a reason...........revving to 9K with a 2.2 head could be asking for huge $$$$ problems.
OG
Originally Posted by OGPackin,Feb 7 2006, 07:48 PM
Im not sure that will matter...?? Im going to use a 3mm head gasket and the 2.2 head has bigger valve springs and retainers then the 03'. The only question i still have are the cams...?? Anyone...?? thxs
OG
OG
Installing stronger springs and light weight titanium retainers will eliminate the problem.
Originally Posted by Sideways,Feb 7 2006, 09:55 PM
You missed the point. The 2.2 head has valve springs that are weaker than the 2.0. This effectively limits the redline with that head. If you rev that head to 9000 rpms you might need a new engine because the valves will float much sooner than the 2.0.
OG
Many on this board have been shifting F22 to 9k reliably for over a year know.
