Using an aftermarket Ignition
Old Jan 31, 2005 | 07:52 PM
tenblade2001's Avatar
Default Using an aftermarket Ignition
I was looking for a high flow cat, and found some info on aftermarket ignition (MSD SCI-L Sport Compact) Here's the link http://www.modacar.com/products/Honda/Accord/MODAIGC/
Any thoughts?
Thanks
Old Jan 31, 2005 | 09:08 PM
Slows2k's Avatar
The SCI box is meant for a distributor based ignition system. It's not compatible with the stock coils. The Stock ignition system is quite good, not giving much issue until the 15psi mark or so with a FI application.
Unless you're planning a turbo, I'd leave the stock ignition alone.
If you did require a upgraded ignition, the MSD DIS-4, or the AEM CDI have been used. The DIS-4 has been more reliable than the AEM CDI. The 2 units install the same way.
Old Feb 2, 2005 | 02:58 PM
Road Rage's Avatar
What expectations do you have for an aftermarket ignition system? Other than the ability to fire multiple times per ignition cycle per cylinder, what is there to gain? The S2000 has high voltage, direct fire, plug mounted coils. Other than bling bling, why bother with it?
Old Feb 2, 2005 | 08:47 PM
Slows2k's Avatar
They only benefits come with a FI'd car. You could always mount the SCI, but it won't work with the coils. It would be mad tyte yo!
dales2000
Jun 21, 2010 09:20 AM
charleetuner
Jun 11, 2010 08:19 AM
jwa4378
Aug 12, 2005 02:24 PM
TrIcKeD_oUt_s2K
Jan 23, 2005 07:47 PM
cjb80
22
Apr 27, 2004 05:29 PM
