using the heat option for the ac
Old May 10, 2007 | 10:24 AM
enrique_s2k's Avatar
Default using the heat option for the ac
I have wanted to know if i set the ac off and dial the temp setting all they way up for heat does this help hot air out of the engine bay. I know silly question just wanted to know cause if not then i should not do it anymore and set it to cool and roll up the windows. Thanks for the info.
Old May 10, 2007 | 10:36 AM
jyeung528's Avatar
to answer your question, yes it does.
secondly...what are you trying to say about rolling up your windows etc.???
Old May 10, 2007 | 10:43 AM
doheboy6's Avatar
Haven't you seen this episode on King of the Hill? Haha
Old May 10, 2007 | 03:47 PM
no cause when I put the temp on the red side it gets a little hot lol..
Old May 10, 2007 | 03:50 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It does not pull hot air out of the engine bay. All incoming air comes through the cowl, and the cabin filter.
it does however help a hot engine to cool down on a hot day (ac off, heat on high)
Old May 10, 2007 | 07:40 PM
R3DS2K's Avatar
heater can help cool the coolant/ engine temp but you are turning on a blower motor to do that.. or u can just let the cooling fans up front do the cooling for you..
even with a car a idle the fans dont stay on all the time..
just drive your car and do what you like
cars designed to take care of it self.. if it is well taken care of
Old May 10, 2007 | 08:43 PM
S2kracka's Avatar
Unless the car is overheating there is no reason to use your heat when its warm outside.
Old May 11, 2007 | 03:10 AM
Billman250's Avatar
Top Answer: 1
I should have added that....this is totally unnecessary on the s2k.
It did help my 1987 t-bird
Old May 11, 2007 | 04:33 AM
thanks guys for the info really appreciate that I didnt have the heat on car ran very well got 27.5 mpg which is very good to me.
Billman250
Sep 22, 2024 11:09 PM
Christople
Jul 15, 2011 02:42 PM
ROTFLMAO
Oct 29, 2010 03:22 PM
nte11igence
Aug 27, 2007 01:27 PM
s2kmaniac81
Jul 28, 2005 02:33 AM
