fresh air setting on climate control
Old Aug 26, 2007 | 11:40 PM
nte11igence's Avatar
Default fresh air setting on climate control
i've heard that the coming from the hot "fresh air" setting is actually engine heat. is this necessarily good to keep it at this setting or is it better to keep it on the cold setting? are there even any benefits at all keeping this fresh air vent open? or is it better to keep it closed? just a curioius question...
Old Aug 27, 2007 | 04:17 AM
snguyen's Avatar
dont set it to anything and turn ot off when its not in use?.. .. i dont udnerstand this thread.
Old Aug 27, 2007 | 04:27 AM
MpBradyS2K's Avatar
When the heat is turned on it is actually heat from combustion gases.
It will not hurt your car in anyway to keep this setting on, however if you keep the temp. on hot, hot air will filter through despite the fans being turned off.
Also the "fresh air" button doesn't need to be turned on for this to occur. Both will send you heat from your engine, where do you think the heat comes from??
Old Aug 27, 2007 | 04:31 AM
snguyen's Avatar
what he said 2 's up
Old Aug 27, 2007 | 05:14 AM
RACER's Avatar
Combustion gasses inside the heater core
Old Aug 27, 2007 | 06:14 AM
__redruM's Avatar
A few steps have been left out, but yes, the cabin heat comes indirectly from burning gasoline in the engine.
The engine coolant acts as the transfer medium from the block to the heater core.
Old Aug 27, 2007 | 01:27 PM
RACER's Avatar
That's like saying the engine charges the battery
Our cars generate heat into the cockpit directly from the heater core via the radiator. Of course the radiator radiates heat away from the engine block, that's just common sense
Ek_Jak
Nov 21, 2015 04:13 PM
ROTFLMAO
Oct 29, 2010 03:22 PM
Pointblank
Feb 2, 2009 04:05 PM
scooby2
Jan 25, 2002 05:24 AM
S2Krazy
Oct 12, 2001 04:56 PM
