using oil relocation kit
Old Oct 3, 2007 | 05:55 PM
s2guru's Avatar
Default using oil relocation kit
i'm using a oil relocation kit, my question is can i leave the stock cooler in place or i have to remove the cooler?
Thank you
Old Oct 3, 2007 | 06:20 PM
Stratocaster's Avatar
I was thinking the same thing, the problem as I see it is getthing a reloation kit that will have a 24M banjo bolt instead of a 22M female banjot nut.
So I installed a Canton.
Old Oct 3, 2007 | 06:52 PM
s2guru's Avatar
when i bought my relocation kit it came with the bolt to hook the oil filter. but if i remove the stock cooler the bolt will be to big for the oil relocation adapter.
Old Oct 3, 2007 | 07:14 PM
If you remove the oil cooler you will see what I mean.
Old Oct 4, 2007 | 04:33 AM
slalom44's Avatar
Top Answer: 1
I have an Amsoil BMK-13 Dual Remote Bypass Filter that uses an oil filter relocation unit similar to a PermaCool adapter.
I left the stock cooler in place. I've had this setup for about 4 years now, with no problems.
Old Oct 4, 2007 | 04:34 AM
AusS2000's Avatar
I have an adaptor that replaces just the filter an screws onto the existing spindle over the stock cooler.
But I wanted to remove the cooler so I took off the spindle and cooler and used the spindle off a civic.
Old Oct 4, 2007 | 05:37 PM
s2guru's Avatar
AusS2000: thanks. now what you do with the cooling lines that goes to the oil cooler?
Old Oct 4, 2007 | 06:17 PM
AusS2000's Avatar
Run then through your turbo of course!
Old Oct 4, 2007 | 06:50 PM
PeanutButter's Avatar
Old Oct 7, 2007 | 06:59 PM
AusS2000
How did you seal up the inlet on the water pump and engine block?
Originally Posted by AusS2000,Oct 4 2007, 06:34 AM
