using an oil sandwich adapter lower oil pressure?
Old Apr 21, 2008 | 06:00 AM
mpower22's Avatar
Default using an oil sandwich adapter lower oil pressure?
Just trying to figure out why my oil pressure is a bit low with my greddy turbo kit. The kit uses an oil relocation kit which lowers pressure I know. Plus I'm using an oil sandwich adapter. Hot idle ranges between 14-18 PSI.
Matt
Old Apr 21, 2008 | 07:34 AM
AP2S2.2K's Avatar
Hmm yeah do you know how much the relocation kit itself lowered you by?
Old Apr 21, 2008 | 08:05 AM
Nate4635's Avatar
There was a thread not too long ago that talked about this - and the debate was more why oil pressure readings differed between a block adaptor and a T connection. Someone with a T connection was reporting lower pressure and I (block adaptor) was reading high? I am around 30psi idle. As much as 90-95psi cruise/accel.
I am N/A, and using the greddy block adaptor.
RedSunS2K
Dec 13, 2011 03:14 AM
skool u
Apr 15, 2009 06:56 AM
mpower22
May 8, 2008 12:24 PM
