VAFC harness too bulky, can't snap the plastic
Old 01-27-2006, 06:20 PM
24s2k7's Avatar
Default VAFC harness too bulky, can't snap the plastic
After putting on the vafc harness, it seems to be too bulky. I can't snap the plastic piece that covers the ecu and hood latch. How did you guys close it with all that wiring all over the place after the harness?
Old 01-27-2006, 07:13 PM
gomarlins3's Avatar
I just didn't put in the rear snap plug. I haven't driven much since the install so I don't know if this will cause any problems or not. Waiting to hear what everyone else did.
Old 01-27-2006, 11:35 PM
RWD_RCKT's Avatar
Most people don't run the back plug.
Some people have actually duct taped the harness wire down before reinstalling the cover. I have no idea how anybody got that to work. It didn't work for me... there is not enough surface for the duct tape to stay put.
I ended up putting duct tape around the scales of the plug and that gives enough friction for the plug to stay put, but also be removeable when necessary.
Old 01-28-2006, 12:12 AM
Former Sponsor
Shadow_S2K's Avatar
The only draw back is you no longer can use the dead pedal. Other than that...not being able to put the plastic piece back isn't a problem.
Old 01-28-2006, 02:17 AM
sebrings2k's Avatar
I fished a zip tie through the hole and got the panel pretty close to stock form. 95% of the dead pedal was usable...
Old 01-28-2006, 05:10 AM
24s2k7's Avatar
95%? You sure it wasn't like 85%? So pretty much, there is no way to get the panel back how it was?
Old 01-28-2006, 09:07 AM
S2000rentacar's Avatar
does anyone have a picture of their install...
i'm putting in my SAFC in a few weeks and I havne't even started to think about even where the ECU is to hook it all up..
i'm a noob
Old 01-28-2006, 11:02 AM
pwrofdrm's Avatar
I spliced mine in so I wouldn't have that problem. It's not as bad as everyone makes it out to be, it's relatively easy and I trust my soldering more than a harness.
Old 01-28-2006, 11:10 AM
axhandler's Avatar
That's what I was thinking. That's what I did when I installed my VAFC in my civic. It's not that difficult to find the correct wires to splice into.
Old 01-29-2006, 04:55 AM
hygiene boy's Avatar
If you unbolt the dead pedal a bit and wedge a small "L" bracket underneath and between the left side of the dead pedal and the ECU plastic cover it will keep things tight and still enable you to use the dead pedal. Does that make sense? It's easier to just do it in person than to try and explain it.
Quick Reply: VAFC harness too bulky, can't snap the plastic
